LG RZ-42PX11 and Samsung HD745 Vs Denon 1910
Discussion in 'Plasma TVs' started by lsalvador, Dec 7, 2004.
  1. lsalvador
    lsalvador
    Nov 10, 2004
    20
    4
    I have the LG anda now i want a new dvd player, and this is my options:
    Denon 1910
    Samsung HD-745
    Other...
    The best choise is....
    Thanks :thumbsup:
  2. neonmod
    neonmod
    I am using the Denon 1910 with the LG and i had to get a decent dvi cable, PQ is OK now and is very good.
    Samsung have brought out a 945 (dvi out) model but i don't know what this one's like!
    Cheers! :smashin:
  3. lsalvador
    lsalvador
    Nov 10, 2004
    20
    4
    Hi, you don't have some problems in denon in dvi ?
  4. neonmod
    neonmod
    No problems as the LG is fully HDCP compliant via DVI, so you can use the 480p, 720p and 1080i settings!
    Cheers!
  5. dezz
    dezz
    I have LG 42PX11 plazma (newer version "with black frame").
    I use this palzma with Samsung HD-935 connected via DVI.
    And result ?
    The picture is fabulous. I use 720p and 1080i, both are nice. :rolleyes:
  6. lsalvador
    lsalvador
    Nov 10, 2004
    20
    4
    Hi thanks for your anwers, is possible put hear some pictures ?
    thanks
