Lg rht599h
Discussion in 'Blu-ray & DVD Players & Recorders' started by Willum08, Mar 3, 2013.
  1. Willum08
    Willum08
    Mar 3, 2013
    I have an LG RHT599H Freeview + DVD Recorder with HDD and am experiencing a small problem.
    If a timed recording has been accidentally programmed incorrectly e.g wrong program selected - I am unable to delete/disable/clear the mistaken selection.
    Consulting the User Manual it states the following on Page 29 :
    "Cancelling a Timer Recording
    To cancel a timer recording before timer starts:
    a) Display timer record list.
    b) Select recording to cancel.
    c) Press CLEAR."
    Having tried the procedure several times, it just does not work !! When the Blue 'CLEAR' button is pressed on the remote control, it just does the same as pressing the 'INFO' button on the remote control - i.e. it displays selected program's information.
    Does anyone have a solution to this problem?
    Thanks.
