Lg Rh7500
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by ian hall, Aug 14, 2005.
  1. ian hall
    ian hall
    Aug 14, 2005
    81
    I am thinking of getting one of these. They are £300 multi region from richer sounds and £244 from Dixons. Is it easy to hack the machine and save £56?????
    Ian
  2. the mechanic
    the mechanic
    Nov 30, 2003
    1,232
    Wrexham,North Wales
    +52
    Hi there,
    Just bought one of these yesterday, and hacked it using this method :-
    Put a region 1 (or whatever region) disc in player
    Try to play the disc
    Wait till the warning message is displayed and it ejects the disc (dont touch anything yet, leave the disc where it is)
    Press the zero button on the remote seven times (0 0 0 0 0 0 0)
    You will then get a message congratulating you for hacking your player, press the enter button on remote, and there you go. Press the eject button to load the disc into the machine, and it will now play.... :thumbsup: .. :clap: ....
    I have tried it with LOST (R1 complete first season), and it plays faultlessly.
    Can't be sure if it plays RCE disc's as I am not sure what DVD's (if any I own) are RCE ?
    Hope this helps you (or anyone else considering this DVD-HDD recorder).
    All the best,
    Graham.
