LG RH7500 opinions
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steve Church, Oct 24, 2005.
  1. Steve Church
    Steve Church
    Has anyone any experience of this machine, especially with respect to its picture quality and editing capability? I want to transfer and edit my digital camcorder tapes.
    Are there any online reviews I can look at?
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    I am also interested in the LG as I am currently comparing it to the Panny dmreh50.
    To be honest , after some searching I cant find many reviews on the LG. I can tell you however that it is Divix compatable which the panny is not.
    I have stayed away from LG in the past, but this particular player/recorder is looking pretty good to me at the moment. :)
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Ok, found some coments on the LG.
    and
    so there you go. Its a toos up for me between the panny and this LG. The Lg just edges ahead with Divix and being cheaper. I have also heard that the apnny does not record 16.9 images.
    However the LG does not seem to record in RGB, which I find very strange :confused:
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    and full specs from LGs web site.
    Broadcasting - Video PAL I,B/G,I/I SECAM D/K,K1
    Broadcasting - Audio NICAM
    Tuner
    Channel Add/Delete Yes
    Channel Auto Search Yes
    Channel Memory 88
    Channel Range VHF E 02~12
    Channel Range UHF E 21~69
    Channel Range CATV S 01~20
    Channel Range Hyper Band S 21~41
    PDC (ACSS/ACMS/ACMS Plus) PDC & ACMS
    Video Plus Yes
    VPS/ PDC/ ACSS/ ACMS Plus Yes
    CH. Add/ Erase/ Auto Search Yes
    Video DAC 54Mhz/10bit
    Audio DAC 96KHz/24bit
    GUI
    Graphic User Interface Yes
    Languages Eng/Ger/Spa/Ita/Por/Gre
    Initial Language English
    Recordable Media
    DVD-R Yes
    DVD-RW Yes
    DVD+R Yes
    DVD+RW Yes
    HDD 80GB
    DVD+R (Double) Yes
    Recording Mode
    DVD±R/RW Single Layer - HQ 1Hr
    DVD±R/RW Single Layer - SQ 2Hr
    DVD±R/RW Single Layer - LQ 4Hr
    DVD±R/RW Single Layer - EQ 6Hr
    DVD±R/RW Single Layer - Auto In case of timer recording
    DVD+R Double Layer - HQ 1.8Hr
    DVD+R Double Layer SQ 3.6Hr
    DVD+R Double Layer - LQ 7.3Hr
    DVD+R Double Layer - EQ 11Hr
    DVD+R Double Layer - Auto In case of timer recording
    HDD - HQ 20Hr
    HDD - SQ 40Hr
    HDD - LQ 80Hr
    HDD - EQ 110Hr
    File Management & Editing
    Menu Display Thumbnail (Title/Chapter) Yes
    Title Delete Yes
    Chapter Delete Yes
    Move Chapter Yes
    Menu Display Thumbnail Preview Yes
    A-B Partial Delete Yes
    Combine Chapter Yes
    Auto Chapter Making Yes
    Hide/show chapter Yes
    Manual Chapter Making Yes
    Title Divide Yes
    Protect Title Yes
    Editing Title Name English
    Disc Protection (On/Off) Yes
    PlayList Delete / PlayList Combine Yes
    sort Yes
    Recording Convenience - HDD
    HDD Time Shift Yes
    HDD Simultaneous Recording and Play Yes
    HDD Clip Recording Yes
    HDD Max recording hours 48hrs
    High Speed Dubbing between DVD & HDD Max x24
    Optimised copy from HDD to DVD Yes
    Back-up Time 3 sec
    Number of Timer recording programs per month 16PGM/1M
    Recording Convenience - DVD
    Safe Recording Yes
    Overwrite Recording Yes
    One Touch Recording / Bi-lingual Recording Yes
    Finalize Yes
    Unfinalize Yes
    Dubbling
    JPEG from CD/ DVD to HDD Yes
    JPEG from HDD to DVD Yes
    MP3/ WMA/ DivX from DVD to HDD Yes
    MPEG2 from DVD to HDD Yes
    MPEG2 from HDD to DVD Yes
    DVD from DVD to HDD (Max X24 High-speed) Yes
    DVD from HDD to DVD (Max X24 High-speed) Yes
    Playback format
    DVD video PAL & NTSC
    DVD ± R/RW Yes (-R/RW in video mode)
    VCD/SVCD Yes
    CD-R/RW Yes
    MP3 Yes
    ID 3 Yes
    JPEG Yes
    WMA Yes
    DviX Yes
    DVD +R (Double) Yes
    DVD-RW (VR Mode) Yes
    DivX Yes
    Xvid Yes
    DivX/ Xvid File Format avi
    DivX/ Xvid Subtitle Format smi,srt,sub
    DivX/ Xvid Subtiles Language 35 Languages including English, Scottish & Irish
    Photo with MP3/WMA Music Yes
    Playble Convenience
    Play List Delete Yes
    Play List Combine Yes
    Zoom Yes
    Marker (Thumbnail) Yes
    Marker Search Yes
    Last Condition Memory Yes
    PIP Yes
    CM Skip Yes
    Photo Album/ Audio Juke Box Yes
    Repeat Play Mode Yes
    Random Play(track) Yes
    Program play(track) Yes
    Auto Dimmer Yes
    Front Panel
    Front AV input Yes
    S-Video Input Yes
    DV Input Yes
    Rear Panel
    Analogue Audio Out Yes
    Digital Audio Out Yes
    Scart 1 Yes
    Scart 2 Yes
    Composite Video Out Yes
    Component RCA type (Y/Pb/Pr) Video out Yes
    Scart RGB/ RCA Component S/W Video out Yes
    Terrestrial RF In & Out Yes
    Accessory
    Remote Controller Type Unified
    Remote Controller Battery (Size "AAA") Yes
    A/V RCA Cable/ Scart cable / RF Cable Yes
    Power
    Wide SMPS 200~240V,60Hz
    Dimension
    Set (WXHXD) 430x348x49(mm)
    Box (WXHXD) 513x455x145(mm)
    Weight
    Net/ Gross 4.5/ 5.5(kg)
  5. Steve Church
    Steve Church
    Yes, I found those as well. I also found several reviews on what looks like a Dutch site. Unfortunately in Dutch.
  6. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    :rotfl: :rotfl:
    :rotfl: :rotfl:
  7. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Steve.
    What made you think about getting the LG in first place.?
    Was it just price or the spec as well?
    Have you had any LG stuff before?
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    well, I think i have decided on the LG. going to go to richer sounds later to day and have a look :)
  9. Ipmack
    Ipmack
    Its a good machine, and I don't have any real problems with it (having returnmed a panny DRM 85 in the past 'cos it was too .... well "clunky" and not user friendly enough)
    I've had 2 to date, returned the first 'cos of vertical lines on the left of the screen on RGB. These disappear if you use component (there's a switch on the back), regardless of whether you are using Scart or other leads. By the way, the 2nd machine has the same problems so I guess that this is part and parcel of the kit.
    Richer sounds are (or were) quite expensive for this believe it or not. It's actually cheaper in Comet so if you do decide to get one, then just ask them to price match. They will BS you and say that their machine is multiregion, but it isn't out of the box. You have to use a hack which they have thoughtfully printed on the side of the box (and which is easy to get online) something like open tray and press 0 seven times (haven't done it)
    let us know what you decide.
  10. jeromeof
    jeromeof
    Aug 26, 2005
    44
    I was also thinking about this machine, I read that it is very easily to upgrade the hard disk to 250GB etc. and it plays DivX. Couple of questions:
    1. Can you edit recording on the HDD
    2. Is it possible to fastforward through Divx movies (I read somewhere it wasn't).
    3. Does it have an RF Modulator, i.e As well as Scart Out does it add a channel to the TV Signal, like a VCR would. I need to know this as I plan to send the output of this device to another TV (in my kitchen) via cable.
    4. How well does the scheduler work.
    5. What is the quality of the output. Does it look the same as the TV (or is is "washed" out colour wise.
    Jerome
  11. Ipmack
    Ipmack
    1. You can edit the recordings on the HDD ( and also DVD until they have been finalised). This is obviously useful for trimming out the ads etc. pretty easy to use too.
    2. You cannot fast-forward using the scan buttons through DIVX. this is a real pain, however, it is possible to jump to a specific time within the file. I haven't tried this after copying the file from a divxDVD to the HDD.
    3. It has an RF loop through, but I don't know whether it does RF out.
    4. The scheduler (timer) is easy to use. Obviously an EPG would be much better, but its as easy to program as any video recorder I've used previously. Also does videoplus if anyone is interested. Can be set to repeat daily / weekly / monthly. The only pain is having to have the machine in standby before it will work. However, it does flash warnings up 10 and 5 minutes before it is due to record something to let you know.
    5. Absolutely no problems with this one. Colours remain vibrant after recording from sky irrespective of quality setting on the recorder. Divx / Xvid files are great. DVD films very good. On the whole very happy with this recorder. Now if only I had my plasma back rather than this poxy CRT...
  12. Steve Church
    Steve Church
    Hi Ipmack,
    Thanks for posting your comments. Can you confirm that the LG machine does not record from RGB (as one review said). I want to connect it to my Freeview box. I have downloaded the manual but can find no reference to it
  13. Ipmack
    Ipmack
    Not entirely sure how to prove or disprove this.
    Certainly my Sky box is set up to RGB out, and connected to the LG via scart. Recordings work fine with a good PQ. Seems as though recording from RGB works.
    Is there any other way of connecting via RGB??
  14. Steve Church
    Steve Church
    Hi Ipmack,
  15. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    The LG will record an RGB signal, but when you play it back it is in composite. It still however, in my opinon, has a better pic than VHS. The LG will out put an rgb signal or component signal when playing back a standard pre recorded DVD movie.
  16. Steve Church
    Steve Church
    Ive just spoken to LG customer support who say that the machine will record and playback in RGB (they looked at the manual). However I can find no reference in the Spec section of the manual (download from LG), but there is a switch on the rear to switch the output from composite (phonos) to RGB (scart) which is documented, so from this I deduce that it will o/p RGB. Still not sure about the RGB input though. Connecting up only the RGB lines in a scart cable would be one way of finding out I suppose.
  17. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Have been using the LG since yesterday.
    It will out put RGB from a pre recorded DVD such as starwars.
    It will not record RGB. I know this from recording CSI Miami on channel five last night from my sky digi box.
    It will also not loop through an RGB signal. It says it is RGB but it is clearly not, just standard composite.
    However, this is a minor niggle for such a universal player.
    Considering how many formats it will play back, and the quality of the recording on the hard drive in HQ and SQ modes, I am still happy with the recorder.
    The quality even in composite , of the recording is so much beyond VHS its really quite amazing.
    I have a Pioneer 757ai for playing back of DVDs via component anyway, so again the RGB issue is not that a big a deal, considering what you are getting for the money. Divx playback is good as well, (the lack of it is what put me off the pannasonic)
  18. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    Filenames must be in dos 8.3 character format which is a bit backward.
    Did that in windows 3.11. Why haven't they moved on like windows did years ago.
    The 3 is the file extention (mp3, jpg)
    That put me off buying since all my mp3 and jpg filenames are larger than 8 characters.
    You can show id-tags but only one at a time. That doesn't help when you have a large list of mp3 files.
  19. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Dont wish to sound dumb, but that is well over my head :D
    whats that mean in laymans terms? :D :)
  20. Ipmack
    Ipmack
    This doesn't seem to be the case.
    It seems to display the long filenames just as well as most windows computers, and in a font which is really easy to read on screen. it seems that as long as the last 3 (the .jpg / .mp3 / .avi) are present the it doesn't matter what the preceding filename is, even if it is blahblah.hdtv.lol.[eztv].avi for example....allegedly
  21. addicksfan
    addicksfan
    I've just bought LG RH 7500 and have a couple of problems I posted yesterday. Having just read through this thread confirmed my knowledge is very limited so can someone explain what is RGB.
  22. theblackbag
    theblackbag
    A connection can be Composite or RGB, with composite the picture is transfered complete, with RGB it is split into the Reg Green and Blue elements and each transferred separatly.
    Composite > Good
    RGB > Better
    My reading indicates that the 7500 outputs RGB, but inputs composite. I did read somewhere that if the machine is in standby the passthrough is RGB but this has been contrdicted in this thread.
    I was seriously considering the 7500 but instead plumped for the Pioneer 433 HS , it does not do DIVX, but for me this was a bonus rather than a must have. It costs about £20 more but the features made the price hike worthwhile for me. I will be pluging it in tonight.
  23. mrparis
    mrparis
    Jul 25, 2004
    10
    Well I took the plunge and ordered an LG 7500 last week from Currys. They where offering it at an average Price £249.00 but I thought the idea of buying locally outweighed the slightly cheaper price on the net.
    On the whole I was really happy with it, I liked the user interface, easy to use and nicely laid out. The ability to play Divx and mpeg4 was pretty cool, apart from not being able to fast forward though the movie, but I could live with that. By far the best feature was the editing (for removing ads) and again was very easy to use and worked really well.
    However after 6 days use, my harddrive died in the machine, so all I ever got when attempting to power on was a “Please Wait” message in the LCD display. Took it back to Currys (thank god I purchased locally) and confirmed the drive was dead and offered replacement or refund. Very disappointed, I know there can be an odd lemon or 2 but I opted for the refund and now considering purchasing either a Panasonic or the Pioneer.
    Overall, I was happy with the machine, but here are a few Cons I found with the machine:
    1. The cooling fan – After a while it become a whining, wiring noise, which never shuts up. Could be why the machine died. Has anyone else experience problems with the cooling fan?.
    2. The size of the unit. It is huge compared to some HDD/DVD writers on the market
    3. The remote – Small matter, but why hide some of the buttons behind a drop down panel which can nearly result in a form of hari kari. Bad design.
    Hope my experience/review helps.
  24. timmy2
    timmy2
    I cant believe that having a DVD recorder with no RGB in is acceptable at all. Mine is going back to the shop ASAP.:thumbsdow :thumbsdow
  25. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Is it possible to permanently connect a Sky STB and Freeview (twin scart)STB via their scart connectors, at the same time, so that I can watch one while recording another?
  26. rhumber
    rhumber
    Nov 23, 2005
    73
    9
    Nr Bedford, UK
    You only have 2 scart connections on your RH7500 so you would need to connect the AV1 on DVD Rec to TV AV1 and the Sky STB AV1 to DVD Rec AV2, then you could connect your Freeview box AV1 to your Sky Box AV2 and see if that works ?
    I have my VCR connected to Sky Box AV2 via Scart, then Sky AV1 to AV2 on DVD Recorder then connected to AV1 on DVD Recorder to TV AV1, works fine with the bypass on my Panny EH50.
    Failing that you could do the above but instead of putting scart from Freeview AV1 to Sky STB AV2 you can put it directly to your TV AV2, but then you wouldn't be able to record anything off freeview which I don't think would be a problem for you as you have all the channels on the Sky STB anyway?
    Hope that all makes sense? :confused:
  27. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Thanks Rhumber,
    I haven't bought the DVD recorder yet, Or the Freeview STB. I am checking on all the 'ins and outs' first. I will keep your notes.
  28. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Do you know if it will play back RGB from a DVD recording made using iLink, e.g. a camcorder?
    Has anyone used the LG playback on say a 42" plama or a large LCD screen?
    I am sure there would be a considerable difference between composite and RGB.
    I have a gadget, purchased years ago at a cost of £70, which converted the composite output to RGB. It made a difference, but only if I was close to a 33" screen. Problem being, it's just adding another bundle of spaghetti wireing.
  29. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    More ramblings.
    Can't record AVI files?
    Spotted on other forums:-
    Posted: Thu Dec 08, 2005 2:05 pm Post subject:
    I have the same problem with my LG RH7900 recorder. I called LG Helpline in Holland. They say it is not possible. It really s#cks because my hard drive is filled with divx movies which I cannot copy now. The (Dutch) manual is also not very clear about it. It states that you can select the media when you want to copy files, in practice regretfully you can only select the HDD media, so i guess that the manual is theoretically right. They might have mentioned however that it is not possible to select the dvd media. It's a great recorder, but I wished I had known this beforehand. If someone else did succeed in doing this hdd to dvd copy, I also would be very grateful to know how.
    For those of you interested if you want to make the LG7500 region free just open the disc tray and type 0 - 6/7 times and congratulations you are now region free will appear on screen.
    Any comments on above?
