LG - RH7500 - AV1/RGB constantly on TV screen
Discussion in 'Blu-ray & DVD Players & Recorders' started by hangten0, Aug 27, 2006.
  1. hangten0
    hangten0
    Wonder if anybody help me, I have just purchased a LGRH7500 recorder, it all seems to work fine (well so far) but apart from an irritating "AV1/RGB" constantly on the top left of my TV screen, and I cannot find anywhere to disable this :confused:
    Any advice would be greatfully received (have searched the forum to no avail)
  2. hangten0
    hangten0
    Looks like it might be down to my TV set as Panny TX28PN1, when I plug another output into AV2 this also comes up on the screen, no luck with the pannys instructions on how to get the input type to disappear:confused:
  3. superbike999
    superbike999
    Mar 16, 2006
    240
    Southport
    +19
    Try pressing the "i" (for information) button on your remote.
    If that doesn't clear it, try pressing the green button on the remote
    Dave
  4. hangten0
    hangten0
    Thanks Dave, you're a star:thumbsup:
    the i button did the trick:clap:
    cheers, henry
