LG RH7500 (80gig) RH7800 (160 gig)
Discussion in 'Blu-ray & DVD Players & Recorders' started by podgerodge, May 10, 2005.
  1. podgerodge
    podgerodge
    May 5, 2005
    28
    I see the LG RH7500 (80gig) RH7800 (160 gig) are available in Europe and the RH7800 seems to be nearly identical in features to the upcoming Sony HX710 but with the added advantage of Optimised recording from HDD to DVD.
    http://www.lge.com/catalog/prodmode...400000&globalCode=DR7800&globalSuffix=000000#
    My big question is whether there is simultaneous recording and playback on the same drive (apart from the timeshift of the same program) . I got a copy of the manual and it will only state that:
    "Playback and recording for both DVD and built in hard
    disk drive (HDD) are completely independent. For
    example, you can record to either the DVD or HDD
    source and play back video from the other source at the
    same time.
    1. Start recording.
    2. Press HOME to display the Home Menu screen.
    3. Use the v / V / b / B and ENTER buttons to
    select a different media type that you want to play
    back.
    4. Start Playback.
    The recording will continue while playing back the
    media from the other mode."
    I'm suspicious that they say for example - do you think they mean you can't do it on the same drive? Any help appreciated before I think of purchasing! The Sony HX710 can definitely do the above.
  2. claire grimshaw
    claire grimshaw
    You can!!!
    you've probably made your decision by now, but I bought one yesterday and you can playback and record to/from the HDD simultaneously. :clap:
  3. Topgunn
    Topgunn
    Dec 2, 2004
    44
    The 7900H is also available in Europe, with an added HDMI connection, sadly no scaling available.
  4. KDH
    KDH
    Apr 22, 2004
    89
  5. Tony Monaghan
    Tony Monaghan
    I've bought one too - & have the same question - hoping Claire can enlighten me as to how to do this. Presumably can only be possible to/from HDD. This is my second DVD recorder (previous a tangent) It's heaps better in terms of functionality and easy of use although the Tangent was perfectly useful, silent (no fan) but got too hot.
  6. Seneca
    Seneca
  7. the mechanic
    the mechanic
    Nov 30, 2003
    1,193
    Wrexham,North Wales
    +52
    Now down to £269.95, BUT I bought mine for £249.99 from COMET and multi region hacked it myself using this method :-
    1: try and play a disc from another region
    2: wait for the cannot play disc message
    3: the disc will eject, but dont touch it leave it alone
    4: press ZERO seven times on the remote ( 0 0 0 0 0 0 0 )
    5: you then get a message congratulating you on hacking your player
    6: press the ENTER button on remote to confirm
    7: press EJECT on remote to load the disc, and away you go
    £20 cheaper than RS and a free MR hack to boot.... :thumbsup: ....
    All the best,
    Graham.
  8. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    I've ordered one of these, but I've just found out that the thing won't record scheduled programmes unless the unit's on standby. Does this mean if I'm watching something I've recorded previously that it won't record my scheduled programmes? If so, that's an absolute pain in the butt - and really a good enough reason not to buy it. :eek: :mad:
    Does anyone with one of these units find it's a problem?
  9. theblackbag
    theblackbag
    The 7500 is currently £175 from komplett.co.uk, a few questions.
    Should I been looking for a differnet device at this price point,
    Will an extra £10-£20 get me a much better machine.
    Anyone got any feedback on Komplett?
  10. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    Note that that's the DR7500, not the RH7500. The DR doesn't have a HDD so doesn't have time-slip, etc.
  11. theblackbag
    theblackbag
    Yes just worked that out, sorry for the misinformation.
  12. theblackbag
    theblackbag
    Sorry to bug everyone but...
    And, anyone who has one of these, what sort of volume does it run at when playing back or recording from the HD/DVD? I assume it does have RGB scart out (but not in), and I have read somwhere it passes through RGB scart when off, is this correct?
  13. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    Well, it's looking bad so far. Seems that if you're watching something from the HDD then scheduled recordings aren't carried out. It also seems that if a scheduled recording to HDD is in progress, you can't time-slip that recording or watch another programme previously recorded onto the HDD.
    Looks like my unit'll be going back. :-(
  14. akane_1984
    akane_1984
    Oct 25, 2005
    6,163
    Belfast
    +170
    i bought one it has to go away for christmas but had chance to play about with it last night, i love it just few pet hates, i recorded a few mins of "the box" to HDD and when playing back it seemed to stutter at points. but picture quality is excellent and tuner fantastic within mins it found all available channels for me.
    Does anyone though use this recorder with NTL Analogue, to view NTL channels i have to hit AV button unlike before when cable was on ch6 or something like that. pet hate but it buggin me.
  15. ferris57
    ferris57
    Jan 18, 2003
    869
    Sorry to hear that :( looks like I'll deff be giving the 7500 a miss then.
  16. addicksfan
    addicksfan
    I've just bought RH7500 which is connected to both Sky digibox and TV via scart and have following problems :-
    1) Whenever switch to AV2 (DVD connection) picture always reverts to 4:3 even though setting ticked on 16:9. I then resize via TV remote and if then use DVD to record or play or do anything, picture again reverts to 4:3
    2) On AV1 (TV) connection I get my normal sound including rear speakers on Sky but no sound from rear speakers if on AV2 (DVD) although get full sound when playing a DVD
    3) Recorded film from Sky onto DVD +RW OK and plays back RH 7500 but not on another DVD player. I assume this is some form of copy protection. Any way round this.
    Hope someone can help with anu or all of above.
  17. akane_1984
    akane_1984
    Oct 25, 2005
    6,163
    Belfast
    +170
    what does time-slipping do???
    and when i recorded a few minutes on my rh7500 and played it back it seemed to stop start at times. this was inSQ.
  18. WebReaper
    WebReaper
    Jul 15, 2002
    117
    16
    London
    Time-slipping is where you watch a programme behind the live broadcast - i.e., the show is being recorded live, but you're playing back the recording a few minutes later.
  19. richiecas
    richiecas
    Dec 29, 2004
    87
    I was all set to buy a sony recorder HX510 or 710 when I seen this. I am planning on getting a sharp LC37P50 screen and like the idea of a HDMI connection from the DVD recorder to the TV. What is the picture quality like from this recorder when playing back DVDs and is it easy to edit recordings such as removing ads etc. I would like to copy whatever is on my sky+ to the HDD on the recorder, edit out the ads and unwanted material and burn to disk. Is this very straight forward
