LG RH4820 vs Panasonic DMR-E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by bluemonday, Mar 13, 2005.
  1. bluemonday
    bluemonday
    Hi all,
    I've been looking at DVD/HDD recorders for a while now, and have come down to a choice of these two.
    There's only a couple of queries I have really... Firstly, does anyone have any experience or knowledge of the LG? I can find very little information about it, though it seems from the specs to be a fairly decent machine and the build is quite good.
    The Panasonic looks good, and the specs are good and it gets good reviews everywhere. My partner has one concern though. We have a Panasonic SL-DT100/SA-DT100 dvd player/amp/speaker system, and want to make sure that the remote controls wouldn't interfere with each other. I think it would drive us mad if the control for one switched the other on and vice versa.
    Any thoughts? Is there any good reason to get one over the other?
  2. nypdblue
    nypdblue
    May 18, 2004
    38
    11
    Hi, I've had the LG RH4820 for a month now and have been extremely impressed to a point, the record quality on the hard drive is excellent, also likewise on DVD though you are limited to a good 2 hour quality and a fairly poor 4 hour to copy a film onto DVD.
    The features on this model are endless, the timeslip function is brilliant and you can archive upto 7 hours viewing and record any part that you've already viewed, also the editing functions are excellent.
    My only concern is that as with my last model LG 4912 it developed a lip synch problem and one month into using this model a simliar problem has occured, so it's back to the store again. I don't no if it's just bad luck on my behalf or a problem others have also encountered.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    23,184
    Warwick
    +3,784
    They shouldn't do - but if they do there is a simple menu option to set it to a different setting.
