LG RH4820 info request
Discussion in 'Blu-ray & DVD Players & Recorders' started by chrisebabey, Sep 23, 2004.
  1. chrisebabey
    chrisebabey
    Sep 23, 2004
    32
    Hi, i'm new to this great forum. I can't find any info on the internet about this LG DVD recorder/HDD player not even on the makers home site.
    What i'd like to know is whats good and bad about this Model?
    Will it record ok from Sky?
    thanks for any info.
  2. glesgaguyav
    glesgaguyav
    Jul 30, 2006
    1,143
    63
    Glasgow,Scotland
    +117
    I've had mine for 2/3 years now and never had any problems, my model is LG RH4820FVL, it's probably been superceeded by a newer model, that's why the lack of info, the only drawback in my model is the 80gb HD it's ok but if you're lazy and don't backup the progs you want to keep, it soon fills up:D
  3. Miles High
    Miles High
    Jan 22, 2007
    99
    Sussex
    I've had mine for getting on for a couple of years I guess.
    No problems other than as below and yes it will record from Sky, I do it all the time.
    One problem I have had for a few months now - any dvd-rw disc I put in it (to dub from the hdd) is not recognised. Ive tried discs from panasonic, mawell, memorex, mr.dvd - all to no avail. I try to initialise the discs each time but that doesn't work.
    Does anyone know what I can do about it? :lease:
