LG RE44SZ21RD NTSC/PAL60 Problems
Discussion in 'General TV Discussions Forum' started by Debonaire, Feb 13, 2005.
  1. Debonaire
    Debonaire
    Feb 12, 2005
    11
    Can anyone help me with this please.
    I got this TV last week, and overall extremely happy with it. However I do have one issue. Whenever I have the set display either PAL60 or NTSC, I some slight discolouration on the lower half of the screen. It's only really noticable on greys and bright parts of the image.
    I have a multiregion DVD player & chipped Xbox through component & gamecube through scart on AV1 and i get the same thing on all.
    Has anyone else encountered this, is it a fault (my Bro has one too and has the same problem) or is there something that I can do to eliminate it.
    I would appreciate any help :lease:
  2. Debonaire
    Debonaire
    Feb 12, 2005
    11
    thnx bud,
    Strange then, that both my brother's and mine have this same problem.
    I'm hoping that someone here can shed some light on this for me
  3. Debonaire
    Debonaire
    Feb 12, 2005
    11
    Hey Lion.
    Can I ask you, do you have your DVD player set to NTSC or PAL output?
    The reason i ask is, that was the "soloution" I received from LG:
    "Thank you for your e-mail
    Yes the unit can use a ntsc singnal. I would recomand setting the dvd to out put a Pal singnal this should
    stop the problem."
    I found this reply to be just short of an insult. So you see why I'm asking you the question.
    Cheers :rolleyes:
