Lg Re44sz21r Dlp Tv
Discussion in 'Televisions' started by IainB, Aug 26, 2005.
  1. IainB
    IainB
    Aug 26, 2005
    27
    3
    Hi folks, new here.
    I have been having a quick look throught the threads on DLP back projectors, can't see what I was after so:
    Has anyone with an LG RE44SZ21R had the following problem?
    I bought on of these last February (2004) and have been very please with it, however a few months ago we had problems with it no starting up, when going to switch on fron standby the led flashes but the TV doesn't start it just goes back to standby. The only way to get the TV to start is either to upnplug it for a while, if that doesn't work the other option is the unplug the set, remove the bulb, replace the bulb. plug back in a nd start, this normally works.
    Now this is annoying when it happens every few weeks but it is now sometimes twice a day so I am loath to turn it off but of course that has bulb life imlplications.
    When I bought it Currys threw in a 5 years guarantee so an enginner is coming out on Wednesday to have a look, third time, so I would like to be armed with some info if possible.
    Thanks in advance.
    Iain
  2. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Very common fault I am sorry to say.
    (Lion are you reading this ;) )
  3. IainB
    IainB
    Aug 26, 2005
    27
    3
    Any idea if it's fixable??
  4. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Yes, you need to have a board swapped out.
  5. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    yet another LG 44 bites the dust :eek:
    I'm so lucky I got the only good one they made :smashin:
  6. Baldgit33
    Baldgit33
    I also have this problem occassionaly . It seems to happen more frequently if my sky/freeview boxes are switched off so I leave my freeview box switched permenantly ( 11 watts on\10 watts standby ! ). You could also try switching on using the TV/AV button on the remote. This seems to work (fingers crossed!).
  7. avinitski
    avinitski
    Apr 22, 2005
    3,310
    +215
    ive had my LG for about 4 months now....hope i got a good one too! lol
  8. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    :hiya:
    this worldwide (first reported in australia) problem with the LG seems to appear once they are over a year old,
    so at 4 months you should be ok, ( although blondie another forum member had a new one with the problem :eek: )
    I've had mine for 14 months now so as you can imagine my nerves are shattered, I cross my fingers every time I switch my precious on.
    actually that's a lie :D
    I extended my guarantee for 12 months so I don't need to worry :thumbsup:
  9. IainB
    IainB
    Aug 26, 2005
    27
    3
    Do you have a link to the reports of this problem elsewhere, I'm trying to get a load of info for when the engineer turns up on Wednesday.
  10. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    :hiya:
    put lg 44 into the forum search and you should find plenty of info from blondie on the subject.
  11. IainB
    IainB
    Aug 26, 2005
    27
    3
    TA
  12. IainB
    IainB
    Aug 26, 2005
    27
    3
    Engineer arrived this morning and has arranged to get the set picked up tomorrow for fix, funny how he knew what the problem could be before he even looked at it!
    Can someone tell me how to check how many hours use the bulb has had??? I can't find it on the standard menus, I belive the set needs to be put into service mode but engineer didn't have the info with him!!
    Ta
  13. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    press menu on the remote and menu on the front of the tv at the same time to enter the service menu, lamp hours used are in there. :)
  14. IainB
    IainB
    Aug 26, 2005
    27
    3
    How the bloody hell do you do that then, I just get the normal menu, tried pressing both together, one on remote first, one on TV first!!
  15. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    perseverence grasshopper :D
    keep trying, it's both buttons at the same time, you'll soon get the hang of it,
    I just checked and mine has 263 hours on the lamp. :thumbsup:
  16. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    No wonder its still working, it's practically brand new. [​IMG]
  17. IainB
    IainB
    Aug 26, 2005
    27
    3
    Set was collected on Wednesday for fixing, Mastercare cover. The engineer on parting says it could be the control board or the ballast or the lamp and the lamp isn't covered by the warranty! surprise surprise so I am expecting a call in a few days saying ' the lamp needs replacing' now can anyone tell me how much they are and more importantly where I can get one from, I'd like to be in a position to say bog off I'm not paying £*** when i can get one from xyz at £**.
    Iain
  18. lasercutter
    lasercutter
    £280 was cheapest I found, would be nice if it was cheaper elsewhere.
    LG lamps page
  19. IainB
    IainB
    Aug 26, 2005
    27
    3
    Thnkyou lasercutter you are a star :thumbsup:
  20. IainB
    IainB
    Aug 26, 2005
    27
    3
    Got the TV back the other day
    New Lamp unit, new Ballast, new support bracket and support bracket something, £403, but I didn't pay for it.
    The TV now starts up faster then it ever did, 12 flashes of the power light as opposed to the 18 it used to do. Lets hope the fix is permanent.
