LG PX4DV with 5.1 speakers - will it look naff?
M
MartyUK
HI There,
Looks like im gonna buy the LGPX4DV plasma (after scouring these forums) but i am also looking at buying an all in one home cinema set up too. Due to kids crawling on the floor i want the home cinema speakers wall mounted and just realised that this would mean mounting the two front surrounds next to the LG's existing built in speakers
Is this a naff way of doing it? (maybe the LG speakers are removable?) has anyone else got a similiar setup, what do you think this will look like guys??
Martyn
M
MartyUK
Just been reading a few other threads and if anyone can quickly let me know the differences between the LGPX4DV and the newer LGPX5D it will be appreciated
Marty
M
MartyUK
Thanks for that and for clearing up the SD HD issue
I assume that this is your actual screen? is it the SD version if so are you pleased with it?
p.s - nice cabinet and mounting!
Marty
M
MartyUK
Brough the Versa 42" wall mount bracketfrom richer sounds the other day as i wanted to get it mounted and start cutting holes, but i am worried that it will not fit the LG PX4DV
Can i ask what bracket you used for your plasma? - was it "VERSA" compliant?
Marty
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
