LG PX11 and DVI dvd player. How to get audio to screen with no amp?
Discussion in 'LG TVs Forum' started by bigval, Mar 15, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    About to buy a Samsung HD 745 for my px11 and connect via DVI.
    I believe DVI carries no sound. How can I connect this player so I can get audio to the screen without using an amp?
    Anyone help.
    Sorry if its a daft question.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Stereo out from DVD player on phono pair, I'd expect to find a 3.5mm jack next to the DVI port on the screen.
  3. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    Yes I have the 3.5mm jack. So will it connect from a 3.5mm jack on back of the dvd player? Or will I need something different?
  4. LG Chet
    LG Chet
    Nov 23, 2004
    125
    As MAW said - Phono pair out from back of dvd player then into the 3.5mm jack input, you will need to go buy a cable.
