LG plasmas, PB and PN series 60" - which to get?
Discussion in 'LG TVs Forum' started by JonasCarlsson, Jun 20, 2015.
  1. JonasCarlsson
    JonasCarlsson
    Aug 13, 2010
    110
    +4
    I'm a bit tempted at getting my hands on one of the last plasmas on the market and I've located a 60PB560 and a PN650 series one. Don't need it to have a lot of fancy functions as long as it does put on a good image (with those less than superb blacks in mind) really, one with good colours and doesn't blurr so easily.
    Cheers!
  2. hodg100
    hodg100
    Reviewer & News Writer
    Aug 8, 2005
    14,105
    3
    4
    +4,468
    Form previous experience, I would bet there would be little difference between those two and I've always liked the motion handling of LG plasmas, so you should be good with either (weak black, aside).
