LG Plasma RZ42PX11 Sky code?
Discussion in 'Sky Digital TV Forum' started by Enquirer, Apr 17, 2005.
  1. Enquirer
    Enquirer
    Anyone got a working sky code for
    LG Plasma RZ42PX11 a member on a different forum seems to have tried everything but cant get one to work .
  2. Bluevanman
    Bluevanman
    Most LG sets use the Phillips code of 0081, but not every set responds to the codes.
  3. Cynthia 7
    Cynthia 7
    Hi Enquirer,
    Last month one of our members was also asking the same question without success. He said he had bought a new remote Rev 4. He mentioned the codes he had tried(Click on Search at the top of this forum). However both Sky and Sky+ latest models are Rev 6. I saw these on the letsautomate.com site. There is meant to be another upgrade to Sky remotes. I read that it was meant to be out end of last year and maybe that is this version 6. Whether it's worth risking £14 - £15 I couldn't say, it would be so frustrating if it still didn't work. Probably the next remotes will be programmed with newer televisions.
  4. cha1kie
    cha1kie
    My father has just bought one of these and has the same problem. Did you find a solution?
