lg plasma problem
Discussion in 'Plasma TVs' started by roofer, Jan 15, 2004.
  1. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    the tuner box for the display is faulty, so iwould like to do away with it as the display has only component inputs how would i connect a netgem receiver?
  2. KevinWood
    KevinWood
    Dec 9, 2002
    101
    19
    Stirling
    I'm guessing the Netgem has a RGB Scart output, therefore you would want to invest in a Dr John Sims RGBtoComponent Convertor (do a search as loads of posts on this). There are alternatives, but this solution is generally regarded as the best (certainly on these forums!)
    Kevin.
  3. BKATZ
    BKATZ
    Aug 4, 2003
    162
    If you have the latest software, the Netgem will output component, (via a converter) & selected via its menu.
    B.
