LG Plasma Panel tweaks for better blacks.
rob80b
WARNING:
AVForums, and LG, in no way endorse, or approve this kind of adjustment, which will of course nullify any and all warranty on your tv.
And also, AVForums, and LG in no way guarantee a fix/improvement, or personal safety, when removing the rear of the television, and indeed try to manipulate the internals when on, and will not, and cannot be held responsible, if and when things go wrong.
Hi folks
Thought I’d bring to attention something that was started while back on the German site.
“Poti tuning of the LG-PK series - the right way to Black”
Poti Tuning der LG-PK Reihe - der Weg zum richtigen Schwarz, LG - HIFI-FORUM
Googles English translation.
http://translate.google.com/translat...-141-2177.html
I’ve started a similar thread over at avsforum.com LG Plasma Panel tweaks for better blacks. - AVS Forum which has gained in popularity, and a lot of good input and feedback.
I personally believe it’s something that LG should take a serious look at if they wish to be a contender for the best plasma.
First we’ve achieved trouble free deep blacks, in some instances rivaling Panasonics top offerings .003/.004 mll and the other benefit is a reduction/elimination in IR, the two things holding LG back from top status.
Why bother, because IMHO LG offers one of the best plasmas in overall picture and color fidelity. The tweaking to lower the MLL has produced stunning results while maintaining all of LGs strong points.
As I mentioned recently over at avsforum, it’s like adding a sub to an all ready excellent sounds system, deeper base.. deeper blacks.
If a few tweakers can obtain incredible results with the black levels with a few twists of the available pots I'm sure LG should be able to do one better.
We have discussed the fact that LG may have adjusted their sets for trouble free operation as apposed to optimum blacks, but the potential is already there and most likely needs just a little encouragement.
rob80b
WARNING:
Thanks Rottenfox
I would believe with your higher native voltage than we have here in Canada and the US these warnings should not be taken lightly, all the same once you've bought your TV it's yours to do with what you please.
If you decide to try the adjustments please read the service manuals thoroughly and follow safety procedures.
Robert
Canada
Badger0-0
Robert, seeing as you're going down this road, links to the Service manuals and the training guides would be very useful, if you have any :smashin:
rob80b
Hi Badger
You can find them on the avsforum thread, but my real incentive posting here is that you have an LG team on board and to bring to their attention the potential of their current plasmas which quite often get reamed in the discussion forums with regards to black levels and image retention, both of which have been have been solved by a few industrious individuals and minor pot adjustments.
I really like my LG plasmas, 4 to be exact, and chose them each time over the competition because of the natural color and gray scale performance, but even I acknowledge their two weaknesses, the higher MLL and excessive IR.
With a few minor adjustment I greatly improved the performance of my PG25 from 2008 and my PX950 now produces equal or better blacks than Panasonic's current top models while maintaining all the qualities which made LG great to start with, IMHO I believe I can now honestly say my PX950 is now a flagship without rival.
Robert
Canada
Badger0-0
It's all good Rob and I understand totally your reasons for posting :smashin:
My only qualms would be to ask what the downsides are?
See, this is the part I don't get.
If it were so easy, surely they'd do it at the factory (yes I understand mass production and everything not being ideal etc)?
Are you saying you're altering the pots so as to attain ideal performance or is it more about running the set outside it's limits, hence possibly shortening the lifespan?
I'd love LG to acknowledge this and explain exactly what the technical reasons are why it shouldn't be done (the safety side apart).
rob80b
Hi Badger
Actually the tweaks may possible extend the lifespan, lowering the MLL I believe requires less current, not a whole lot less, but less.
"If it were so easy, surely they'd do it at the factory", we've been asking that question for awhile now, the only answer is that it gives less margin for error, therefore less returns, service issues, therefore more $$$$, but at the same time hampers sales- less $$$$, look at the forums, and you see who's buying what. I'm sure LG worked out the numbers.
Personally I can sleep easy with a few pixel misfires for a much improved fabulous picture but there are consumers who will scream bloody murder with one bad pixel.
I see parallel lines with those who use to tweak their CPUs to max out clock performance, there may be a give and take, but the benefits far out-way the negatives for the savvy hobbiests.
At the same time LG have invested millions and I would believe that their R&D team could easily produce the same performance we achieved with trouble free operation.
rob80b
FYI, one of the posters (tweakers) rpauls actually tweaked his panel to spec. as per the training manual with a scope and multimeter and got the results we were looking for. The biggest deviation came from the Set-up and Set-dn which were not properly calibrated at the factory.
LG Plasma Panel tweaks for better blacks. - Page 18 - AVS Forum
(Maybe because LG's panel technology is so similar to Panasonic's that they may be bordering on patent infringement, staying with a higher MLL may keep them out of conflict, who knows?)
Robert
Marc
i would like to add that i've done this to my 60pz570 and achieved much deeper blacks :) It's amazing how much better everything looks with a proper black level!
Marc
it doesn't crush it, as far as i can tell. Can still see the same black bands as before on the AVS 709 disc
rob80b
What does this do to shadow detail?
Hi muffins
Because all that is being done is creating a deeper black base or MLL for the overall picture, the shadow detail is actually improved.
Now, if you had previously dropped your brightness to give a "perceived" lower black level you may need to increase it a notch, otherwise everything should remain the same including any calibration that was previously done.
Marc
Interesting. I'm still reading the AVS thread but am hesitant to try anything.
from someone who was also hesitant, there's not really anything to worry about with this. On my set at least you can take the back off without breaking any warranty seals so as long as you don't make a pigs ear of removing screws it shouldn't be obvious you've opened it up, and the dials don't permanently break anything no matter which way you turn them so just take a note of their starting position and you can't really do any harm.
Insanity202
I wish I still had my PK590 to have a dabble with this :(
rob80b
Thought I'd I quote Big Brad from today at AVSFORUM
LG Plasma Panel tweaks for better blacks. - Page 25 - AVS Forum
Big Brad said:
I was finally able to get my Eye One LT to produce a useable and sustainable reading on a 0 IRE test pattern using Color HCFR. Honestly, I'm not sure what I was doing wrong before (I've never had issues like the in the past), but now I never get the "No data from sensor message" at all.
Well, the results are quite impressive. I measured my 50PK550 yesterday a few times over the course of the day. The 0 IRE read a consistent .005 MLL. I'm amazed at how low that is. Overall effective contrast has almost quadrupled, going from 1900:1 pre-tweak to a little over 7000:1 post tweak.
I initially thought that maybe I could get it a little lower with a bit more tweaking, but I decided to not attempt it as my OCD personality would never let it rest (which is why I kept at it with my Eye One LT). .005 is very, very good if you ask me. I was actually impressed with the way my greyscale and primaries/secondaries have held up. It's been about a year since I did my last calibration, and I've decided to hold off on the calibration until my TV replaces my old projector in my theater room. But it looks like I'll just need to do a few things to get it back into spec. My gamma is still spot on at 2.20.
rob80b
Hi Muffins
I was hesitant and I started the AVS thread, just do not touch anything that does not need touching and watch the edges of the back panel, they are sharp, otherwise it's a piece of cake.
Not too sure about the screws for the European versions but the North American versions have 3 screws in and around the HDMI and RCA jacks that can be easily missed.
Good luck.
rijwog
Hi Guys,
Reading this with interest.
Marc - you have a PZ570, yes? I know you've mentioned links to what you did, but my head is spinning somewhat going from link to link to link -
I know each set may be slightly different, but can you write a brief post summarising the poti changes you made?
Thanks Rob for the heads up on this!
Cheers,
Marc
ok, sure
i turned VY all the way to the left and VA all the way to the right. I turned Set_UP all the way to the right, and then turned Set_DN to the right until the picture went noisy, then turned it back until the noise went away.
I'm not completely done, as turning one of those has made whites a bit noisy/grainy in 24p mode but it's not that noticeable with contrast down a bit or power saving on so i've not got around to having another go yet. Apparently tuning VS a little bit could get rid of this noise.
rijwog
Thanks Marc - appreciate it.
...now to stop looking at the back with my screwdriver and time to have a go:eek:
Marc
good luck :) don't forget the 2 screws by the component in and the 1 by the usb, they're easily missed
and don't touch anything inside the tv apart from the dials, apparently some bits have an electric charge!
oh and make a note of the starting position for the dials so you can restore them if you need to.
muffins
Interesting that there isn't more interest here as there is in AVS. If it wasn't such a PITA for me to get to the back of my tv I would have done this already.
Just need to get the finger out.
Courtjezter
Marc,
Now that you have done this are you a lot happier with the TV, than you were initially?
Marc
yeah, i am no longer trying to sell it so that says it all really. The blacks still aren't perfect but i found if i turn off power saving mode then they are very good indeed (even a little bit of white on the screen creates enough contrast to make the blacks look quite deep) and in an all-black screen they're probably about 10-20% darker than before. The TV looks infinitely better in daylight conditions now too, instead of the light washing the image out, it makes the blacks look deeper which is strange (unless the sun is shining right on it of course)
Courtjezter
I may have to whip the back of my telly then. Not that i have been unhappy with it, but if i can make something better, then i have to give it a go.
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
Trending threads
Latest News
Ennio Morricone: Legendary film composer dies aged 91
  • By Andy Bassett
  • Published
AVForums Podcast: 5th July 2020
  • By Phil Hinton
  • Published
Sky comedy panel shows back to film new series
  • By Andy Bassett
  • Published
Polk launches MagniFi 2 soundbar
  • By Andy Bassett
  • Published
Samsung pulls out of IFA 2020?
  • By Andy Bassett
  • Published
