LG, plasma or LCD - please help
Discussion in 'LCD & LED LCD TVs Forum' started by Kine, Nov 27, 2004.
Tags:
  1. Kine
    Kine
  2. tmp
    tmp
    Nov 23, 2004
    271
    Bristol
    +12
    I am having the same problem was all set to purchase a LG DI30LZ30 then found this forum and now cant make up my mind.
    It's down to personal preference and features that you need on the TV and the amount that you are willing to spend.
  3. Dmitry Markov
    Dmitry Markov
    Hi Kine!
    I think if you gonna use your display for PC purposes than you should turn towards LCD. Using plasma with still pictures would cause some problems especially burnt label of broadcasting company somewhere on a screen or Windows pannels that you will be watchin' forever even if you do not use a PC at the moment.
    And some other details like resolution which is vital parameter for PC graphics, and so on.
    So my advice will be - LCD!
    But there can be other oppinions:)
    Good Luck!
