lg plasma and toshiba dvd picture question
Discussion in 'LG TVs Forum' started by bobbyrandall, Dec 23, 2004.
  1. bobbyrandall
    bobbyrandall
    hello all.i have a toshiba sd900 that i was using with a tosh 32in widescreen
    with no probs.recently got in an lg plasma 42 pz 43.picture quality is generally very good but on some scenes eg certain darkness scenes or when there is mist or close-up of peoples faces the image goes a bit fuzzy or to be more precise like a halo of colour contrasting wrong. have i set something wrong?? have i got a dodgy plasma? can i adjust any of the settings? i only play region two discs straight from the shop. at the moment i use component output. i have tried the video output with same results. any suggestions anyone with the same kit????thanks.my mrs says im going on about nothing but it annoys me.
  2. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
  3. bobbyrandall
    bobbyrandall
    ok grahamtriggs thanks for the reply. whats dve or avia???im a long way from the uk and we are not too clued up here.
