LG Plasma and Pronto
Discussion in 'LG TVs Forum' started by House, Jun 17, 2003.
  1. House
    House
    Dec 19, 2002
    571
    Essex
    +10
    Is anyone successfully using a Pronto to work their LG Plasma ?
    If so any chance of a copy of your .CFF file.
    Thanks.
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Have you tried www.remotecentral.com yet?
    I managed to create a complete set up for my system from files downloaded here. Although, I did create my own for my CD player.
    All the best,
    Dr John Sim.
  3. House
    House
    Dec 19, 2002
    571
    Essex
    +10
    John, yes got everything from there except for the Plasma.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I know of no LG codes for pronto, you are out on your own mate. Obviously it's not hard, but it's the lack of discrete codes that is the problem when creating macros. I did an LCD panel that had no discretes by using succesions of toggle commands that overrride each other, if you see what I mean. In fact I recently reprogrammed a DIY job pronto for a PW5 where the guy had done the same thing, used the PC toggle command to reset the 'input' command, so it would reliably switch to S-Video. It's the best of a bad job sometimes.
  5. mikeblanche
    mikeblanche
    I have a OneForAll 6 successfully controlling my LG PZ17 plasma. (no discrete on/off or input codes though).
    If you know of a way of converting the codes from OFA format to CCF format (using the JP1 software?) then this could be one way of creating a CCF file.
    mike
