LG PL7 XBOOM Go Wireless Speaker Review & Comments
Amar
As ever, thanks for the excellent comprehensive review. Will you ever be getting any review samples from Minirig?
Steve Withers
Reviewer
I believe Ed Selley is planning to review more wireless speakers, so maybe.
Evinger
Thanks for the Review Steve.
And, much better to have a Boom Go Speaker than a Speaker Go Boom! ;)
invisiblekid
Nice review Steve.
At this price point, the XBoom is running against a range of Ultimate Ears, which I don't know how the XBoom compares, but I'd probably pick a Meridian designed speaker over those.
Gary J
In my experience, a problem with these rubber coatings is that they absorb moisture over time, and end up very sticky.
Don Dadda
I found the same issue on a couple of remotes with rubber coating but never knew what caused it to go like that. A nasty feel to it. Ended up using some cling film on the casing so i can hold it.
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
