LG PC1D Plasma makes a loud cracking noise
tp.white
LG PC1D Plasma makes a loud cracking noise when it starting to warm up.
I realise that this is not normal, should I insist that Empire Direct exchanges it for a new one.
It is only 4 days old.
TOM.
stainway
If you mean the 2 clicks you hear when starting up-that’s normal.
After switching on-should be quiet-otherwise ask for replacement.
tp.white
:thumbsup:
Thanks Stainway.
One more question. I`ve tried to find the remote codes for the ntl samsung stb (blue remote) Can`t find them. Help.....
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
