LG OTW420B wall mount bracket
aandpwoodley
I need some advice please.
I have the official LG wall mount bracket OTW420B which is Vesa 400x200, 300x200
The new TV I'm looking at is 300 x300
Can you get a conversion plate or something so I can use my existing mount ?
Sloppy Bob
Looking at it, to me it seems like it's possibly a wall mount only for specific LG TVs, it's not designed to be compatible with other TVs.
If you could add plates to that, they may interfere with the operation of the mount as it's so slim.
aandpwoodley
I'm assuming the adapter plate will attach to the back of the new TV and then attach the LG wall bracket will attach to the plate ?
Sloppy Bob
I'm looking at that and thinking it's designed to fit specific TVs. For £20 you can buy a wall mount that's designed to fit all TVs and comes with the parts you need.
If it was mine and I didn't have the correct TV to fit it, I'd buy a different one rather than mucking about with plates that might hinder the mount from working correctly.
Ultimately it's your TV, your mount, your choice.
aandpwoodley
I understand your point, however re-using a bracket that is already fixed to the wall surely makes sense ?
From what I can tell this bracket should work with any tv proving the vesa holes match up
reddkryten
Sorry to derail this thread, but I have a related question.
I’m about to replace my old but beautiful plasma tv, which comes with it’s own table and a stand so the TV is held midair.
I believe the current tv has a vesa 600 x 400 mount. While the replacement tvs all seem to be vesa 300.
Would getting an adapter work? I haven’t found one on amazon yet, is 600 such an old standard that it is extinct?
noizer
I have the same wall mount with an E6 and I am waiting for a C1, would this mount work with newer tvs?
420B
Newer 480B
iu
