LG OLED65B7V wall mount challenge
Discussion in 'LG TVs Forum' started by joker_zero, Dec 8, 2017.
    1. joker_zero
      joker_zero
      Dec 4, 2004
      224
      Been looking at the LG OLED65B7V in store thinking it would decorate the lounge nicely, when I noticed the port arrangement on the rear.
      Rear facing ports are a deal breaker as I mount direct to the wall, with a low profile visa mount and have cabled running through buried conduit for a nice clean finish.
      No problem at first inspection, some optional rear facing ports but nothing I actually intend to use.
      In fact the only things I care for are power and ARC supported HDMI as everything else switches through an AV amp.
      Then I see a problem, it seems LG have decided to add a curve to the back white plastic cover such that once on the wall it will be impossible to see or access the otherwise sensibly side facing ports.
      Madness!
      Anyone run into this, or am I missing an obvious solution?
      Trev
