LG OLED65B7V Audio Advice Required
Discussion in 'LG TVs Forum' started by Pecker, Apr 3, 2018.
    1. Pecker
      Pecker
      Dec 26, 2004
      22,453
      Huddersfield, People's Republic of Yorkshire
      +4,558
      I've just ordered one of these, to be delivered on Friday:
      LG OLED65B7V 65" Smart 4K Ultra HD OLED TV
      :clap:
      I would potentially have a maximum of 3 x HDR/4K sources, 1 - a UHD Player, 2 - a Sky Q box and 3 - an Amazon Fire TV.
      I have a legacy (non-HDR/4K) amp, which I'd like to keep. The problem is, of course, that I can't plug any of these sources into the amp, then one HDMI from amp to LG, as the amp won't pass 4k/HDR.
      Now I haven't bought the UHD Player yet, but will buy one with 2 x HDMI outs, so there should be no problem with the amp there. HDMI 1 to carry video to the LG, HDMI 2 with the audio going to the amp.
      The Sky Q box has an optical out for Dolby Digital, which is the best audio format available on that box, so again I'll plug the HDMI straight into the LG, and take an optical digital out to the amp.
      Now, this Fire TV (like the Sky Q box, the best audio is Dolby Digital) only has 1 HDMI out, and no separate audio out. But the LG does have an optical out.
      Three questions:
      1 - Can I plug the Fire TV straight into the LG, then run the optical out from the LG to the amp? In other words, will the LG pass an audio feed it receives over HDMI out through the optical output? Or is the optical out only for content where the LG is the source (internal tuner, apps, etc.)?
      2 - If so, could I also do this with the Sky Q box, so I only have to run one optical cable (LG to amp) instead of 2 (LG to amp and Sky Q box to amp)?
      3 - Does the above set up look right? Any potential problems?
      Many thanks.
    2. drdocmatt
      drdocmatt
      May 23, 2016
      815
      63
      GB
      +284
      I believe the answer to 1 is yes. In fact you don't even need to use the optical out use the HDMI ARC channel and it'll carry all the audio you need, up to but excluding (I believe) HD soundtracks.
      I believe the fire TV needs to be forced to output 5.1 audio, otherwise it will default to 2.0. again the TV *should* pass it through the ARC to the amp.
    3. HSC
      HSC
      Nov 23, 2004
      2,043
      63
      Coventry
      +199
      yes ARC
      assuming your amp supports it
    4. GAmbrose
      GAmbrose
      Jul 5, 2003
      1,113
      63
      Essex
      +241
      Sky Q actually supports Dolby Atmos for some shows, so in actual fact Dolby Digital isn't "the best audio format available on that box"
      You've spent a fortune on an amazing OLED TV - Can't you stretch another £350 for a Denon AVR-X2400H?
    5. mkebbay
      mkebbay
      Apr 12, 2005
      220
      +10
      What amp do you have?
      I also have a similar set up to you i.e. same tv, Sky Q, UHD player and legacy amp. You can try the option you suggest using the tv's optical out to the firestick. Depending on whether your amp has the ARC feature you may be able to connect the ARC input from tv to ARC input on amp.
      This will allow you you to send Dolby digital sound direct to the Firestick and even Sky Q without the need to use optical leads. I have my set up connected this way. The only drawback is that you cant get HD audio over ARC such as DTS Master audio or Dolby True HD but as you will be getting a UHD Blu ray player with two HDMI ports that should not be an issue for you.
    6. Pecker
      Pecker
      Dec 26, 2004
      22,453
      +4,558
      Good spot. But I believe it only carries Atmos over lossy DD+. No matter, I don't want, nor require Atmos.
      I have a rather fantastic ONKYO TX-SR876, which I'm loathe to part with. I don't need Atmos, so to get anything of a similar standard in terms of amplification and DACs I'd have to shell out 4 figures, and I'd barely get 3 figures for the Onkyo on ebay. I just seems like a complete waste of both quality and money if I can work round this.
    7. dollag
      dollag
      May 30, 2015
      1,812
      116
      Kent
      +750
      Cant you just run an optical out from the TV to the avr?
    8. Pecker
      Pecker
      Dec 26, 2004
      22,453
      +4,558
      Erm...that's what I'm asking.
    9. dollag
      dollag
      May 30, 2015
      1,812
      116
      Kent
      +750
      apologies :blush:
      I was having handshake issues with my hdmi on a previous set so ran everything via optical from the tv to my av receiver. worked a treat.
      I cannot see any issues other than the carrying of immersive and hd formats (and dd+) which you are already aware of.
    10. GAmbrose
      GAmbrose
      Jul 5, 2003
      1,113
      63
      Essex
      +241
      Sorry, that was a typo
      New AVR is £350 not £3050!
      They've come a long way in 9 years...
    11. mkebbay
      mkebbay
      Apr 12, 2005
      220
      +10
      Is there not an argument to spend similar amounts on AVR, speakers as with the tv?
      I would not put a budget amp £350 with s premuim tv £1500+.
      The OP already has an amp that is in the premuim range which i suspect would do a great job over HDMI ARC. As the OP stated replacing hid current amp would require the sort of investment that could get a decent tv.
    12. Pecker
      Pecker
      Dec 26, 2004
      22,453
      +4,558
      Thanks for the ideas (and the correction, I'd guessed it was a typo).
      The thing is, if I'm not going down the Atmos route (which I'm not), and I've found a solution to the Fire/Sky Q issue (which it looks like I have), I'm guessing this would still be a case of me spending more money for lower quality.
      I don't know the spec on that Denon, but at the price I doubt it'll have DACs as good as the Onkyo's Burr-Brown 192 kHz/24-Bit set up, nor 200W per channel in amplification.
      Though I'm happy to be corrected.
    13. Pecker
      Pecker
      Dec 26, 2004
      22,453
      +4,558
      The TV has already set me back £2.5k, so I'm certainly trying to minimise other expenditure where possible.
    14. drdocmatt
      drdocmatt
      May 23, 2016
      815
      63
      GB
      +284
      I would agree, you have no need to replace the avr.
      • Thanks Thanks x 1
      • Agree Agree x 1
      • List
