Hey guys,
Just after some advice as not to sure on how to go about this,
I have a OLED65B7 that was purchased in July 2018 from Richer Sounds.
A few weeks back it had developed a fault where it kept switching off after a few seconds.
Previously i had also noticed some pixel degradation but had put off calling it in, but as the tv now had a major fault mentioned all the issues.
The TV was collected and returned after 2 weeks stating all issues were sorted and also the panel was changed.
However after checking the panel was the same and also the warning for the power board was still appearing. Also the rear panel was not clipped back in as there was now a gap along the back and the HDMI input was also being problematic after return.
Had contacted RR again and they politely rearranged collection with the repairer to reinvestigate.
The engineer has been back in touch with RR and they have mentioned the panel issue is screen burn/image retention and not covered under warranty.
Richer sound have suggested to contact LG directly for a panel replacement and they will reimburse the £300 cost after as a one off gesture.
My concern is that i should only really be dealing with Richer sounds on this and sounds like a bit of a run around to get the tv sorted which is still under warranty.
Also the annoying issue of being without the TV for a few weeks whilst this is being checked by a engineer.
Please see pictured attatched. I would like to think the green line along the top is not possible from screen retention and would have been covered.
Any advise in this situation as even if the panel was replaced it seems like it will likely happen again from what i can see in other threads people have mentioned.
