Question LG OLED55C7 - 50W usage in Standby / Off When using remote - 0W when using button
Discussion in 'LG TVs Forum' started by TheBlueRaja, Jul 19, 2018.
    1. TheBlueRaja
      TheBlueRaja
      Feb 26, 2006
      650
      +69
      Hi All,
      I bought one of those killawatt things to monitor my energy use and i noticed that my OLED pulls around 45 - 50W whilst turned "off" by using the remote control - if i turn it off using the button at the back of the telly it drops to next to nothing.
      Now this is with Quick Start+, the Standby Light and "Mobile TV On" turned off.
      To put that in perspective, that's going to cost about £60 a year just to have the TV turned off but plugged in.
      This seems very high - any ideas as to why it would be? The PDF for the C7 says its should only be 0.5W. http://www.lg.com/us/support/products/documents/OLED_C7_Series_Spec-Sheet.pdf
      This is on firmware 4.70.95.
      Any ideas why?
    2. wezzywebb
      wezzywebb
      Feb 12, 2004
      8,354
      2
      fishburn
      +8,518
      Are you sure it wasn’t doing a compensation when you tested it ?
    3. TheBlueRaja
      TheBlueRaja
      Feb 26, 2006
      650
      +69
      Hmm,
      I have noticed that it does eventually drop to almost 0W after a certain amount of time (over 10 mins at least).
      I suppose it could be that...
      Does it normally do it after every use? As I've seen it at this level for a few days now after switching off.
      Just never got round to checking out after a around 10 mins had passed.
    4. wezzywebb
      wezzywebb
      Feb 12, 2004
      8,354
      2
      fishburn
      +8,518
      After 4 (i think ) hours of usage it runs a compensation while in standby
