LG - OLED55C6V Screen Burn - Currys Knowhow Policy
Discussion in 'LG TVs Forum' started by rhysmaclaren, Aug 20, 2018.
  1. rhysmaclaren
    rhysmaclaren
    Sep 9, 2008
    11
    I purchased a LG - OLED55C6V back in January 2017 with Currys Knowhow policy.
    The tv has developed screen burn from a kids tv show NIC HD.
    Am I able to claim for this to be fixed by LG or Currys Knowhow guarantees?
    The tv has a pixel shift process which I thought was supposed to resolve this issue?
  2. d10brp
    d10brp
    Jul 6, 2008
    1,686
    116
    +784
    Usual questions:
    - Did you leave it on standby when not using or switch it off at the wall?
    - Roughly what % of your viewing was that channel?
    - Got any pictures? SB usually shows up best against colour slides
    - What OLED light setting do you use?
    I don't know about Currys specifically but I believe that LG have been a bit better about admitting panel variation issues causing SB recently and may do a panel swap
  3. iwb100
    iwb100
    Feb 28, 2011
    8,912
    163
    +4,225
    Technically neither will cover screen burn.
    Best bet is to try Curry's say it has developed a faulty screen. Do not say screen burn. They may do something.
    If that fails try the same with LG. However it is out of LG warranty period so they will almost automatically do nothing.
    I suspect you will be out of luck, but you can try and push it hard with Curry's and kick up a fuss. Do not use the word "screen burn" and if they call it that and refuse to do anything keep insisting that they sold you a TV not fit for purpose.
