Hi all,
Proud to say that I'm the owner of a new LG OLED48C14LB.
However, I've got quite a big problem that I'd like help with: I can't get the TV to passthrough Dolby Digital Plus [DD+] to my AV Receiver (Pioneer VSX-531). AVR is connected via ARC on HDMI port #2 on the TV. AVR also definitely supports DD+ as I used it for almost four years with my old TV to successfully receive a DD+ signal. My new TV only seems to want to passthrough regular, non-plus Dolby Digital [DD] for some reason
I've tried:
1) Different streaming apps built into the TV. I've tried a number of different movies on both Netflix and Amazon Prime Video, and they all still only output mere DD, when I know that virtually all content on both these platforms has a DD+ audio track (correct?)
2) Linked to above, I've even tried streaming the exact same movies on the exact same streaming services on my Nvidia Shield (non-Pro) plugged in via my AVR. This produced a DD+ signal absolutely fine, which my AVR picked up.
3) I've tried fiddling about with the sound settings on the TV, and have configured to be the following way:
-DTV Audio Setting: has been set to 'AUTO'. (Its also strange that it gives an option to force DD+, when it doesn't seem to want to output this in the first place - I have tried forcing it to DD+ and it makes no difference)
Select HDMI Input Audio Format: has been set to 'BITSTREAM'
Digital Sound Output: has been set to 'PASS THROUGH'
eArc has been set to 'OFF', since my receiver only supports regular ARC. (I have also tried it with switched to 'ON' and this made no difference)
4) I've even tried plugging my Nvidia Shield directly into one of the non-ARC HDMI ports on the TV, and my TV still only outputted regular DD to my AVR. So this would lead me to believe its very likely an issue with the TV, rather than my AVR
I've been on chat with LG today about this problem. I ran through what I'd already tried, and they seemed to think it might be a hardware/manufacturing fault. How likely is this? Is there anything more I can try? really don't want to go through the faff of exchanging a TV when its bulky and inconvenient to take back to Argos.
I've tried:
