bossDida
Hello there,
I recently bough a LG OLED GX and I was enjoying the view but all of sudden image started to change in disturbing way. I contacted LG technicians and explained my concern as best as I can but somehow they claim there is noting wrong with my tv.
I'd like to share a few images and ask for your opinion. Is it a general case for all LG OLED tvs or it's just me.
Blacks are terrible through edges as you can see from images. Technicians think it is all about resolution by I face the very same problem with 4K and DolbyVision as well.
At the Image_03, you can see the grey screen just before tv is opening Netflix application. I thing there are obvious grading problems with this panel. At Image_02 you can see same pattern as well which is HD stream content from Netflix.
Is there any one who experienced same problems or anyone who can enlighten me about the situation.
By the way LG Turkey is not helping at all and I try to contact to LG Global. If any of you have LG Global customer service contact email, it would be great if you share it with me.
Thanks in advance.
Best regards.
Thanks in advance.
Best regards.
