Nice! Congrats! Make sure you get them wires buried!!
CheersCable is fixed and not detachable from TV. it will be fitted with an appropriate plug to connect to the mains to suite the local territory, in UK std 3 pin. I believe that the lead is around 2m long?
I have the Denon AVR-X7200WA. Full Atmos in house.What denon amp do you have ?
Soon to be owner all being well 65 inch arriving next week
Going to be wall mounted using a Vogel's THIN 546 wall bracket which unfortunately will have to be installed before the TV arrives
Can anyone please confirm the distance from bottom of the TV to the bottom VESA hole?
I've seen somewhere in the thread I believe that the distance is around 210-215mm is that correct?
Thanks in advance for any help
Listen from 9:27 onwards
Connect to hdmi 2 from tv and all others to denon amp , set hdmi deep colur on,I have the Denon AVR-X7200WA. Full Atmos in house.
Stay in isf dark if you watch in a dark environment or isf bright if you watch in a lighter environment , filmaker is not the most accurate mode but with dolby vision you cant access filmaker mode anyway ,so dont worry your not doing anything wrongOne more query,
playing the film 1917 on my 4K player. When I go into the settings I have no access to filmmaker mode in picture settings. What am I doing wrong ? Dolby Vision is enabled.
I have my Xbox series x connected to the telly via hdmi into hdmi 4. This way I get access to 120fps but the downside is I only get tv speaker sound.
Would I get access to AV receiver sound if I connect to the telly via an optical cable and make sound out adjustments in the telly menu ?
Got it working with an optical cable. Tried arc, gave up as I couldn’t get it to work but probably my bad.Is your receiver connected to the TV via HDMI 2 and does it support ARC/eARC? I may be wrong but you should be able to use ARC here to achieve the same thing with needing an optical cable (I think!)
I bought my telly 6 days so complained to Curry’s, got an instant £200 refund. Yay !Taken the plunge as the TV has come down £200 today £2299.00 and bought the 65" from John Lewis with the 5 year protect plus which I believe covers burnin. Paid using my Revolut card so should get 2% cashback. Delivery on the 31st cant wait.
