Hi guys anyone have actual measurnent for 65 gx from top of tv to lugs as in midst of building a stud wall to support tv when it arrives monday cheers
attached may helphttps://www.lg.com/us/PDF/Gallery_Series_Mechanical_Drawings_v4.pdf
Do you have any dimensions?Anyone seen these recessed boxes in the UK? Only seen them in the US for about $37. Shipping costs the same!
Can’t you just make one with some 50x25 timber and 6mm mdf? It doesn’t need to look good.Anyone seen these recessed boxes in the UK? Only seen them in the US for about $37. Shipping costs the same!
Hi, not sure wood is best thing. Does this help. Adaptable Metal Box 300 x 150 x 75 With Knock OutsAnyone seen these recessed boxes in the UK? Only seen them in the US for about $37. Shipping costs the same!
Why? What’s wrong with using timberHi, not sure wood is best thing. Does this help. Adaptable Metal Box 300 x 150 x 75 With Knock Outs
Or this one 300 x 300 x 75 is nearer the LG size. Thanks for the website tip. If my planned method doesn't work, I may go for this.Hi, not sure wood is best thing. Does this help. Adaptable Metal Box 300 x 150 x 75 With Knock Outs
Has anyone got an amazon fire stick or fire tv attached go this set, will either fit at the back of the tv whilst the tv is flush with the wall i.e. is there enough room in the cable managment part built into the tv?
I had this when first connected my sound bar but I went into sound options and enabled eARC.I've got a GX55 with the LG Gx soundbar connected via a hdmi cable and configured to use ARC.
This has been working fine since installation.
I received an update for the TV overnight.
Now ARC isn't working, only internal speakers on the TV.
Anyone else had this problem?
Thanks for the reply, i wonder if just the plain fire stick will fit?
