infaddict
I've just bought a 65" LG OLED GX TV and matching GX Soundbar. The subwoofer is wireless. On any input source (Sky, Netflix, Xbox) the woofer does a low "grumble". The best description I can give is a bit like the noise you computer hard-drive makes when it is working inside your computer. I have recordings/videos I can share where you can hear it. It is very noticeable on quiet scenes.
I have moved the woofer to within a few feet of the soundbar and the problem still exists. The router is in another room and no other devices close to the woofer. I've forced my 5ghz channel to be 36 (lowest one) to try and avoid any interference but it didn't help.
I guess I could turn off the router completely and try playing something as another test (will do that later when family won't shout!).
I am connected from ARC/e-ARC HDMI port 2 from TV to the Soundbar.
Any help or guidance much appreciated. Its very frustrating and makes this very expensive setup annoying to use.
Cheers.
Cheers.
