LG OLED Firmware 6.00.05
ColdnFrosty
I just installed firmware 6.00.05 for my LG OLED55C7. Does anyone have release notes for this? Thanks.
bear266
[06.00.05]
1. LG Channel has been upgraded and service territory expansion. (Selected Countries Only)
2. Software update contains minor bug fix
Good morning.
This is the first time I write in the forum. Forgive me for my bad English. I have the model lg sj810v and my TV updated to 6.00.05 firmware. Since then the problems started while until then I had none. Sometimes movie playback crashes on usb while before not, I have tried the same movies on another old lg and it plays just fine. The remote control often freezes and they have to wait several seconds for it to come back on and most importantly I have a serious problem with the wifi. It constantly disconnects me, when it connects it locks once at 1.5 mbps another time at 15 mbps etc. and not at the 50mbps it locks before the upgrade. All this in the band 2.4 because in the band of 5 it locks in 0. And all the problems of wifi are in the download, in the upload they are perfect. All the other devices I have connected to the network work perfectly. I have tried to reset the TV, I have unplugged it for 1 hour nothing. And all this after the upgrade. What can I do, can I go through 6.00.05 again and maybe it has not "sat" well? Or can I go through the previous 5.80.35 when I had no problems? What do you suggest to me? Thank you very much.
Clem_Dye
You can't downgrade firmware. In theory, it's possible, but LG doesn't offer any facilities to do so. You could try a factory reset, which will be a pain. Other than that, contact your local LG support service for help.
For the wi-fi problem, could you try an Ethernet cable to see if that helps?
Thank you very much for your answer.
I tried to reset the settings but the problems with the wifi remain.
I have communication with lg, I did what they told me (change dns, etc) but again nothing. The etherhet cable can not be placed in the TV, it is in another room.
Now all I have to do is if there will be an upgrade that I will miss all my problems or take it for service.
Let me ask you, can I reinstall the latest firmware again, the 6.00.05 on the TV via usb?
BVU
I’m having the same issue with my LG SJ850T. After installing the update, the tv started to have wifi connection issues. After 2 days, wifi is totally not working. Not only that, the tv arc is not functioning anymore. On the magic remote, it’s not just slower. The air mouse function is not working. The back and guide buttons are not working anymore. I have done the reset to initial settings but it didn't help.
mesteradam
Good morning.
I have very similar problems. Did you find any solution?
I have 6.00.05 firmware version too. But since the TV updated, if I turn on the TV the download speed on all other devices are reduced extremely. When the TV is off, the download speed is between 20-30 Mbps, when the TV is on (no application started), the download speed is reduced to between 0.4-1 Mbps.
Bowers PI7 wireless in-ear headphones review coming soon to AVForums
