jamiem1987
Also interested in the black level setting given the C9 doesn't have an auto black level setting, is the PS5 limited + TV low okay for all circumstances? Including blurays etc.
The rule of thumb normally is, the settings don't matter, as long as they match.
So, if you have the PS5 set to limited RGB or low black level, the TV should be set accordingly.
That said, @FarleyUK appears to be having issues with COD.
I had my C9 calibrated by Vincent back in February and the picture on the PS4 Pro has been superb.
But playing Spider-man Remastered on PS5 seemed to make the city look a bit to dark. Vincent states in the comments under this video that if you have the C9 Black level set to low (this is what he calibrated my game mode to) as there is no auto then you should put the PS5 in Limited. I have just done this and now the PS5 looks incredible. So this should sort out other's seeing a washed out picture etc.
That’s what I’ve done, but it’s still incredibly dark. Have had to reduce game contrast to
Contrast is set to 7?That’s what I’ve done, but it’s still incredibly dark. Have had to reduce game contrast to 7.
Mine is calibrated to 85 Contrast for SDR
and 100 for HDR
ah ok, I haven't touched any of those settings.Sorry, I meant contrast in the game settings.
This happened with the last firmware I think, can be turned off in the settings - general - additional settings - home settings - home auto launchI don't know if anyone can help but this has me scratching my head, this has only just started to happen and I don't know why, when I turn my TV on the home dashboard comes on, any ideas ??
Cheers mate, I'll try itThis happened with the last firmware I think, can be turned off in the settings - general - additional settings - home settings - home auto launch
Sounds great, will try this tonight as i have noticed darker picture on the PS5.I had my C9 calibrated by Vincent back in February and the picture on the PS4 Pro has been superb.
HGIGSounds great, will try this tonight as i have noticed darker picture on the PS5.
May i ask if you are using dynamic tone mapping or HGIG on HDR Game?
Mines been calibrated to HGIG for PS4 Pro and you should do the same for PS5.Should I turn on dynamic tone mapping for ps5
I haven't got a ps5 yet but this seems bizarre. Surely Sony should have picked up on this during development/testing? What about watching SDR Blu-ray? They expect users to have an inaccurate picture or go into the menu every time?I got my PS5, delivered three weeks early.
I'm a bit pi**ed off you have to either enable or disable HDR on or off permanently. The auto function doesn't function as 'automatically' at all, enabling HDR when it receives the appropriate signal. It just enables HDR all the time.
I'm not leaving it set on 'automatic', as Vincent suggests, not for SDR games.
What a weird implementation, just like Sony do with DV on their UHD players.
Why can't it be left off and only come on when games are natively rendered to utilise HDR?!
Or have I missed something?
It would appear I have to determine games on a game by game basis by looking them up to see which are indeed real HDR.
It does, I tested last month with my Panny player connected direct to the tv and used eArc to the speakers via NAD receiver, DTS:X was passed through without issue. (LG audio - Arc is set to eArc and passthrough).Quick question hopefully one of you kind folk can answer. Does the C9 pass through DTSX via earc? When I tried this on my Series X it just said your receiver doesn’t support this but I know the receiver does. The series X is plugged directly into the C9 and earc sound back to receiver. Atmos works fine just not DTSX. Thanks
Thanks for that. Good to know it isn’t the TV and probably some setting I haven’t checked.It does, I tested last month with my Panny player connected direct to the tv and used eArc to the speakers via NAD receiver, DTS:X was passed through without issue. (LG audio - Arc is set to eArc and passthrough).
