m11rphy
Just a heads up the Apple Website is now show 2018 OLEDs as being Airplay2 compatible, hopefully the firmware update is near; Apple TV app - Devices
This is what I’m seeing on the Apple website and no mention of the C8
Well, just launch the Notifications App to read it again then. It's advance notice of the next firmware update soon. Speculation is that it will include AirPlay2 support is in the posts above. It definitely doesn't say "the firmware is out now, try to get it today"![]()
Hehe, thanks. I didn't even know there was an app showing all the notifications. Learn something new every day!
Just give it some time before making that investment...Hi I have the OLED65C8PLA at the moment. I have the new xbox series X which looks great with it.
Might need to upgrade soon as need HDMI 2.1 for 120fps.
Can anyone point me to the best calibration set up for this please.For Sky Q and Game mode
120fps is also possible in HDMI 2.0, with resolutions up to 1440p.
And I don't see many games hitting that in a near future.
I dont know aboutr game mode but for sky set it to ISF Dark then turn off all the processing.
I've always read the contrary.Sure it's possible. But it's not implemented. The C8 doesn't support 120fps over HDMI.
Definitely agree.With VRR helping. VRR is the game-changer, really.
It does 1080p 120fps over HDMISure it's possible. But it's not implemented. The C8 doesn't support 120fps over HDMI.
There have already been demonstrations, even before the consoles were launched. The choice of 120fps with lower quality, ~90fps with medium quality or ~60fps with max quality is the choice that gamers are demanding, and so it's very likely to be an option on many games. With VRR helping. VRR is the game-changer, really.
But there is no rush. These are early days, and there are several issues to be sorted out with HDMI2.1 implementation in AVRs and newer TVs. Never buy the first generation of anything.
Could you expand on this? Being a 120Hz panel, what's stopping the TV from doing it?
I guess I stand corrected, then.Ok well I've always read what I said! It supports 120Hz via USB files, but not over HDMI. I've got one 120fps test file which pans around a bit. That works. (google "UHD-HFR-Astra.ts" to find it)
EVEN IF it did work over HDMI, the bandwidth limitations make it impractical - you would need to use 8bit for start which means lots of banding, as well as 4:2:0 chroma, etc.
You'll need a 120Hz source to test it, if you want to be sure.
It wasn't implemented. Been reading a few people's unrealistic demands for a magic firmware upgrade to add support for 1440p/8bit/120Hz handling to what's already baked into hardware over the years, but no sign of such a miracle happening.
However now that PC HDMI2.1 cards are available which can output some of these resolutions (eg 8bit banding-tastic 4:2:0 1440p 120Hz), someone can test it and report if it works.
edit: from @Trophy hunter 's post, maybe all the fuss was about 1440p. Was all quite some time ago...
I think the misconception comes from the fact that the C8 supports 120fps via USB. Also, I was under the impression that HDMI 2.0 supported 120Hz up to 1440p without compromisses, but that seems not to be the case as well.
Thank you for the clarification.
Flatpanelshd review actually clearly stats it:Happy to help but this is my memory, so still worth someone testing it to be sure I think.
Let us turn our attention to motion performance. As mentioned, LG’s 2018 TVs are the first to support video at up to 100 and 120 frames per second. This should not be confused with manufacturer’s claims of 100 or 200Hz panels. 100/120fps is also referred to as ‘High Frame Rate’ or HFR and is a development that will finally bring about silky-smooth and ultra-sharp video motion. C8 supports HFR via USB and apps/streaming and our tests on C8 show that it HFR video delivers a striking and very visible improvement in motion. Unfortunately, the 2018 LG OLED generation does not support HFR via HDMI, which puts a damper on things.
Where is that?
I have on Picture mode (User) for Sky Q
Oled light - 90 - <50
Contrast - 95
Brightness - 55 - 50/51
Sharpness - 25 - 0
Colour - 55 -50
Tint -0
Colour temp C20 - Warm 2 which I think is approx W45
Advanced
Dynamic contrast - Off
Dynamic Colour - Off
Preferred Colour All 0
Colour Gamut - Wide - Auto
Super Resolution - Low - Off (although I prefer Low/medium on SKY SDR content)
Gamma - Medium
Picture Options
Noise Reduction - Low - Off
MPEG Noise Reduction - Low - Off unless you see banding
Black Level - Low
Real Cinema - On
Motion Eye Care - Off
Tru Motion - Clear - Off or user 2/10
Is that ok?
