i could be in the same boat. want to upgrade my b6 to a c8 but the price is a out off. do you know when the AF8 is out ??? i need to make a decision on the c8 or AF8 soon as I'm normally an early adopter ....I think the Sony A8F will be the top seller especially if LG keep the idiotic pricing, which is where I’m most likely heading this year
I was told by LE Concepts that they would have them at the end of the monthi could be in the same boat. want to upgrade my b6 to a c8 but the price is a out off. do you know when the AF8 is out ??? i need to make a decision on the c8 or AF8 soon as I'm normally an early adopter ....
Very competitive pricing from the get go by Sony, is that using a 2018 panel and not the same 2017 (2016?) one as the A1?
What do you mean by dv lite? Is the sony using some sub underpowered non stellar dolby vision ?yes it is a good price but there is still the problem of the "DV lite" that sony use and the under powered O/S but if DV and apps are not needed then it could be a good buy for someone keen to get a 2018 oled panel
News & Discussion: Sony Dolby Vision update for Bravia TVs is apparently half-bakedWhat do you mean by dv lite? Is the sony using some sub underpowered non stellar dolby vision ?
5%So can you post pics ,some of 5% slides most people would like to see plus some 100% whites.![]()
Congratulations on your new tv, I'm looking to get a 65 in a few months time. How does 1080p look on the C8?I bit the bullet and had 55 delivered last week.
Prevoisley had the Eg960.
Very impressed so far much improved on early models
