LG OLED B9 Owners and Discussion Thread
cressy75
I have had that issue with the fuzzy line. It appeared on both the the Series X and the PS5. I'd read somewhere that other people were having the same issue and one person had fixed it by unplugging their TV for a short amount of time. So I unplugged my TV from the socket and left it for half an hour and when I plugged it back in the issue was gone. I've read that some people have had it return but it hasn't happened on mine yet.
ianreid2
My OLED55B9PLA was working fine, got up this morning & turned it on, within a minute or 2 the volume started increasing by itself until it hit 100. I am using it on internal speakers. I've powered it down for 10 minutes & removed/replaced the batteries in the remote. It's only 7-8 months old, any ideas anyone?
I have discovered that the issue I'm having with near black scenes flashing happens when I have VRR enabled on my Xbox Series X at 4k 120hz. Disable VRR and the issue disappears.
It's vrr flicker nothing you can do besides dropping to 60 nigh on eliminates it or turn off VRR
V1mFuego2
No problems with the PS5 maybe my Series X has a fault because I can’t find anyone else reporting this problem
It was mentioned a few months ago, all launch Xbox X and S have a faulty HDMI chip. It's not firmware patchable either. Microsoft downplayed it, but also mentioned new units late 2021 with a new hmdi chip rev that fixes it.
shagaboopon
I had that and it went one day after leaving the TV off all night and then came back worse the next day before eventually the screen would flicker a split second and not power on and it needed a new screen when repaired. I suspect you'll find this is a screen fault eventually and will be terminal.
For clarity this is a vertical line that runs the full height of the screen and can actually be composed of one or more columns which can be spaced unevenly and in different colours from White to green.
Where have you seen that late 2021 units have a revision??? The fact you s some of the affected devices have been patched shows it can be fixed
Mr collins
The issue I was having was fixed in the latest Xbox update so it’s definitely not a hardware issue!!
McGherkin
I have to say, having finally got my hands on a HDMI 2.1 graphics card.... I'm so happy I went for the B9. Finally being able to game at 4k, 120hz, with 12 bit HDR, and G-sync all together... awesome.
By the way, if anyone is having issues enabling G-sync at 4k60 or higher, enabling 4k120 at all, enabling 4k60 with anything higher than 8 bit colour - It's your cable. I had a 'certified' one but it was still not good enough, ultimately bit the bullet for a Belkin one (4K Ultra High Speed HDMI 2.1 Cable – 4K HDR | Belkin - You don't need the 8k £60 one) and all is well.
elrafar
Hello everyone... I’m having serious problems on my LG b9 oled and the Apple TV app
i have no sync with subtitles, Apple TV + shows have a lot of problems loading, crashes mid episode, something that don’t happen with purchased movies.
also have random lock ups only with Apple TV + shows or movies
already tryed to reset the app and the tv... nothing helps
LG OLEDB9
Firmware 5.00.15
chomtamp
I have similar problems with the Apple app. Now I cast to the TV using the app on my phone or ipad. Works fine using that method. Not sure if that's an option for you? If not then I think you'd need to wait for it to be fixed via a patch.
elrafar
Hi! I use it to other apps but have not tested for the Apple TV app... does it retain 4K Dolby vision? Or is an airplay 1080p stream?
elrafar
I will try as soon as I get home...
But Apple needs to fix this app... all other streaming apps works just fine.
i’ve tryed to post on their community forums, but all I got was restart and reset help...
mrstruders
Hey anyone who’s got a service remote it is possible to turn off the annoying instant game response logo that flashes up all the time it’s driving me insane ?????
kavie87
Anyone here have issues outputting LPMC via eARC. Have a Q950T that had a new update but any content that is LPMC is being converted to stereo and in surround. Running 5.00.15...
NickSem
Update on my Xbox One X 4K issue. My younger son (who is in our Covid bubble) has just bought an OLED55BX so I took my Xbox One X round there this morning. The Xbox One X does 4K fine with that so it's not the Xbox. I'm still baffled by the fact that some of you have the same set-up and it works. Time for factory reset again now that we've verified the Xbox One X and HDMI cable..
spinoir
You got HDMI deep colour turned on right?
spinoir
Thanks, yes. Actually the TV set it automatically but I double checked.
Thats weird. Had to turn mine on manually. I assume you tried the other hdmi ports? Maybe try turning on Deep colour for every hdmi port even though you aren't using them then try each port again whilst they are all active.
NickSem
Yes, I've tried. Just hoping I can persuade my son to bring his PS5 to supper tomorrow and if, as I expect, the TV doesn't recognise it I'll log a call with Curry's and try for a replacement main board.
NickSem
Damn. My son's PS5 does 4k fine on my B9. My Xbox One X does 4K fine on his BX. So neither device will be accepted as being "faulty" but they won't do 4k together. And yet they do for other people. I'll comb through the diagnostics screens for a clue but I doubt it will help.
Update: The only thing I can glean is that the HDCP 2.2 shows "FAIL" but I think we knew that.
Whereas the PS5 is happy as Larry:
spinoir
View attachment 1495295 Whereas the PS5 is happy as Larry:
So as the Ps5 worked on port 2, did you try the Xbox on port 2 as the info screen says port 3?
What happens when you try to force the Xbox resolution to 4K?
In Video Fidelity & Overscan section of Xbox do you have it set to HDMI or Auto (Override)?
Podcast: Samsung HW-Q800A Soundbar & Rotel Michi X3 Reviews + TV show and Movie News & Reviews
Latest News
Trinnov Audio announces Crestron Home driver
  • By Andy Bassett
  • Published
Rotel announces upgrades to 14 and 15 Series amplifiers
  • By Andy Bassett
  • Published
What's new on UK streaming services for May 2021
  • By Andy Bassett
  • Published
Samsung's 110-inch Micro LED TV on pre-order at Harrods
  • By Andy Bassett
  • Published
Bang & Olufsen introduces Beosound Emerge speaker
  • By Andy Bassett
  • Published
