RickRock
b9 is perfect for the new console.I want to know is the B9 gonna be worth keeping for next gen consoles, with the CX having loads of extra features that the b9 don’t have ?
4k 120hz hdr. that's all
What's the difference between xLA and PLA?FW out for download for the xLA models, I used for PLA/7LA on my SLA with no issues so far.
LG OLED55B9PLA Product Support :Manuals, Warranty & More | LG U.K.
LG Get product support for the LG OLED55B9PLA. Download OLED55B9PLA manuals, documents, and software. View OLED55B9PLA warranty information and schedule services.www.lg.com
Ah no i just meant all the models that end with LA. I think they're all identical, the first letter/number only signifies which language is default and where its sold.What's the difference between xLA and PLA?
Oh, nice one. Thanks for the reply mateAh no i just meant all the models that end with LA. I think they're all identical, the first letter/number only signifies which language is default and where its sold.
Does this mean the new firmware should be imminent for models ending in PUA?FW out for download for the xLA models, I used for PLA/7LA on my SLA with no issues so far.
its out, dont know when its ota. usb file and guide is on the support site:Does this mean the new firmware should be imminent for models ending in PUA?
Preciate the LMGT link, I’ll wait for ota to hopefully come out before I get the new consoles but good to knowits out, dont know when its ota. usb file and guide is on the support site:
Let Me Google That
For all those people that find it more convenient to bother you with their question than to google it for themselves.letmegooglethat.com
I thought the b9 didn’t have the right VRR all I’ve been hearing about the cx is it’s much better VRR Gsync and stuff also 200 nits brighter HDRThat. With HDMI VRR as well.
Haven't seen confirmation by users. Any day now?Does this firmware v5.00.02 add anything for the upcoming PS5 and Xbox Series consoles for VRR and 4K/120 Hz or were they already working before?
Yes 4k120hz 4:4:4 hdr gsync works right now, there werent any 4k120hz sources for the rtings review so they couldnt check could theyDoes the B9 support 4K output at 120 Hz? I know the HDMI 2.1 ports have the bandwidth but RTINGS.com make no mention of [email protected] in their review, only [email protected] and [email protected]
Figured my issue out. Its a combination of things but in short I had to set Nvidia control to off and let Windows handle it set to Auto, it uses 8bit dithering which fixes banding and the color gamut problem. I only get about 92-93% of P3 as opposed to about 97% I should be getting but better than 72% only. It sucks but this seems to be the only way. For now, for whatever reason.G'day,
Just got a B9 65" and trying to calibrate it however I ran into some issues with WCG, using an HTPC and always has in the past. I noticed I am not seeing much if any difference when viewing HDR content either in games or movies. I've checked with HCFR and Chromapure and sure enough it only displays about 73% of P3 which is full Rec 709 despite the TV saying it is displaying BT2020. Also checked dxdiag in windows which also says BT2020 is being displayed however it is not the case as per measurements and my eyes.
What am I missing?
Many thanks
Its simply by taste, trust your eyes. DTM will adjust it scene by scene but may result in inaccurate results sometimes. Peak Brightness I prefer as it will just up the output consistently making it brighter and more accurate.Hi all some help on a couple of picture settings. I've noticed that peak brightness is set to high on both hdr cinema and Dolby vision cinema settings. Should I keep this to high or switch off?
Also dynamic tone mapping is also on. I'm thinking these should be set to off.
Advice!
What firmware version are you running? I have not seen this issue but I am also not on the newest version as it is not showing up for my set yet.Hi
My oled panel has started to develop a faukt where the screen will intermittently go black . The only way to resolve this is to power it off and on again. This fixes the issues but it reoccurs about 10 minutes later. As you can appreciate this renders the TV useless.
I have performed a factory reset and disconnected other devices but the problem persists. Is this a recent firmware upgrade problem? as the issue has only occurred within the last month or so, and I noticed the new setup menus are different.
