Quantcast
LG OLED B9 Owners and Discussion Thread
What are these light strips and why would you want to light up the back of the telly?
It's called bias lighting and you'll find the reasons here:
For my eye, the OLED TV is already too contrasty with too dark shadows, so I use a dim lamp in a corner opposite from the TV and further so it doesn't reflect in the screen. And I also increased the Brightness from 50 to 54 and decreased the Contrast from 85 to 80, OLED Light is at 40, Gamma 2.2. it looks more natural to me, although I'm aware I lost some of those "perfect blacks"...
just try it with my B9, with the lost in space scene.
Like you said, de-judder create artifacts at the value of 2 or higher. I set de-judder to 1 and de blur to 5 and the artifacts disappear. (at least for my eyes)
I tried de-judder 1 and the distorsion is still there but much reduced. de-blur does nothing for 24 fps.
Felix442
Hue light strip connected to hue sync, used for bias lighting and these also sync with the colour on the screen for movies etc. Can all be controlled automatically through hue app, harmony remote and alexa
jole26
The Apple TV app is available this morning for the B9 in the UK. I've installed it and checked it supports DV (it does) and 5.1 audio (it does).
I don't have Atmos to test.
Talkshowchris
I'm still having issues with EARC and this TV.
When connected to my Ambeo soundbar there are times when the EARC function disappears (the lossy version of a sound format is output to the bar, confirmed by the front display and app) and also when audio drops out for a second or two.
I'm really not sure whether it's the TV or soundbar though.
Has anyone had anything similar?
I noticed that there aren't many posts on this whole thread about EARC.
Darth Yoda
Hi there. I've got my B9 connected to my receiver (Onkyo TX-SR507) via an optical cable. When I choose Optical on the 'Sound Out' menu (with the Digital Sound Out option set to Auto), Dolby Digital passes through to my receiver. When I choose Internal TV Speaker + Optical on the 'Sound Out' menu, there is no Digital Sound Out option and Dolby Digital stops working through my receiver and I only get PCM.
Is there a fix for this? It worked fine on my old Samsung TV so I don't think it's a problem with the receiver.
qwerty2k
Very tempted by the 65b9 at Costco for £1499. Just wanted to ask really if you were all happy with your b9 and didn’t regret not going for the c9 instead? Are the apps smooth to use or a bit laggy with the older cpu of the b9?
bobbymax
I for one am very happy with my 55"B9, which had to follow in the footsteps of a Pioneer kuro.
I'm content with saving the money :D
BigPest
Previously Bigpest2724
I really am struggling with the best settings for this tv . I’m very confused with hdr and sdr. When I’m watching virgin on my v6 box what would my setting be?
Use my settings in this thread..it's a best to calibrate lol
BigPest
Lots of people asking for settings ....give mine a go.. Hour upon hour spent getting them right
ISFDark Room preset
Oled light 87
Contrast 88
Brightness 50
Sharpness 10
Colour 50
Tint 0
Expert controls
Dynamic contrast off
Super res off
Colour gamut - Auto (but extended is good too (Don't touch)
Gamma 2.2
White balance - warm 1
All other settings leave
Peak brightness Off
Noise reduction auto
Mpeg auto
Smooth gradation low
Black level low
Motion eye care off
Tru motion off
HDR
Standard setting but just turn off motion
Dolby vision
Just turn off motion
Inferno
I'm going to be a big pest, yes for you and your set they may be, but blah blah blah :laugh:
BigPest
Cheers for the great contribution as always 😂😂👌👍👍
I have the 65B9 for more than 2 months now and I regret for not going with Panasonic or Sony not C9. IMO LG processing leaves much to be desired compared to the others, especially when it comes to motion interpolation (C9 is no different). I use a setting of 4 or 5 for De-Judder because I don't like the natural stutter of 24fps film. If you don't care about this and will switch De-Judder off then you'll not have 90% of my problems (heavy motion artifacts compared to the other brands). Other than this, the general image processing of LG I find not as refined as my former Sony 65XF9005 (returned due to bad bleeding).
The slight lag of B9 menus compared to C9 is not an issue in practice. It is nowhere near as bad as it was with Android on Sony.
qwerty2k
appreciate the feedback. I think I would keep all the motion processing stuff off so it may not be an issue for me. I saw a Sony ag8 I stir at John Lewis and thought it looked great but the software looks horrible compared to WebOS.
albax
ISFDark Room preset
Oled light 87
Contrast 88
Brightness 50
Sharpness 10
Colour 50
Tint 0
Expert controls
Super res off
Gamma 2.2
Peak brightness Off
Mpeg auto
Black level low
Motion eye care off
Tru motion off
HDR
Dolby vision
I don't mean to sound dumb but by switch off just motion, what exact setting in what menu do you mean by that?
Inferno
It's in Picture Mode Settings then in the sub menu Picture Options then in True Motion.
BigPest
When watching hdr and dolby vision stuff your TV changes into hdr mode and dolby vision mode... it changes all of the settings into preprogrammed settings despite you using for example my normal list of settings for regular viewing .... All I did was turn off motion for each setting... Those are then my recommended settings...
albax
Is there a way I can change the hdr mode settings and Dolby vision without watching something of that level? I seem to only be able to change Dolby settings if I am watching a program in Dolby vision which is very rare, same with hdr
BigPest
Just note your preferred settings and input them when the content is on... Best way if its an issue..I'm happy with the hdr and dv settings so didn't change them
Similar threads
Trending threads
Latest News
Bowers & Wilkins CEO leaves amid restructuring
  • By Andy Bassett
  • Published
Xbox Series X, more specs confirmed
  • By Andy Bassett
  • Published
AVForums Podcast: 24th February 2020
  • By Phil Hinton
  • Published
Disney+ announces discount for European launch
  • By Andy Bassett
  • Published
Disney developing AI based video compression
  • By Andy Bassett
  • Published
