fluxedman
- Joined
- Dec 15, 2013
- Messages
- 2,206
- Reaction score
- 1,074
- Points
- 495
- Age
- 46
LG Manual on the cracking/popping noise:
What should I do if I hear popping noises while watching TV or turning TV on or off?
Symptom
Cracking noises are made from TV when power is turned on or off.
Cause
1. Cracking noise
- The noise heard while TV is viewed or turned on or off is due to thermal(heat)
deformation or heat expansion of plastic materials
due to temperature and humidity.
It happens commonly on products subject to heat deformation such as vehicles or furniture.
2. Electrical noise
- It is a subtle sound generated from a high-speed switching circuit when current
is supplied to operate products.
The noise level differs by model.
Note : Noises does not affect product performance and reliability.
It is normal to have a certain level of noise that meets strict standards LG follows
when manufacturing the products, and they are not subject to exchange or refunds.
Help library: | LG UK
Help library: Learn how to use, update, maintain and troubleshoot your LG devices and appliances.
www.lg.com
1. Cracking noise
2. Electrical noise
