LG Nanocell0866 Powering Off
criostoir
I bought the 49inch TV from Richer Sounds on September 16 and am very happy with the TV. One issue I have is that the TV sometimes turns off itself despite the Settings for Power Off being set to Off. Is there another setting I should look for or is this a fault?
Clem_Dye
A fault, in all probability. There have been other reports of LG TVs suddenly powering off. My 2019 model has done it at least 5 times in the year or so that I’ve owned it. Try a factory reset, install the latest firmware, etc. See if you can detect a pattern. If it is a fault, with it being so random, it will be difficult to track down.
criostoir
Thank you.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
