LG NANO75 settings
Steely001
Guys I recently bought a LG 75NANO756PA and I’m currently struggling to find the best settings. Could you help me out? Thanks
next010
ISF Expert Bright/Dark room modes are the most accurate of the built in presets for video watching.
Also have a look at the rtings settings for the UN7300 it may be similar to the TV you have.
alfa159
hello me or a nano91 I advise you to leave the original settings as they are only disable the movement and energy saving put at maximum contrast and brightness so you should have an acceptable image then maybe if you don't like it increase color and put the local dimming to a minimum then maybe you tell me how it goes
