LG MZ42PZ10 a Good or bad buy please help
Discussion in 'General TV Discussions Forum' started by philinman, Jul 6, 2002.
  1. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    :confused: Hi i was going to buy an LG MZ42PZ10 plasma screen from currys as they seem to have it at a good price
    £4000 and it comes with stand , tuner box and speakers . does anyone know if this is a good deal as i have looked on the net and it seems cheap .All the other sites you have to pay extra for the stand ect ect
    Also they are offering 2 years 0%
    So any advice would be good thanks
    phil :p
  2. Guest
    This model looks very nice and the picture is very good, a local store has it side by side with the much vaunted Panasonic,
    and in all honesty there is hardly any difference,
    and I am sure I have seen the LG on offer at Richer sounds for £2999 including VAT. but I just checked there site and its not listed, but it is definatly in a recent magazine, so it might be worth ringing them, before parting with your hard earned £££££,s
  3. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    I have been to the site and at first look it looks cheaper but you only get the screen , no stand , tuner box , speakers and it is a differant model number but idont know what the differances are and as normal they advertise it on the web site at a great price but have none in stock but when they do the price normaly goes up :D
  4. Guest
    I am 99% sure that I saw the LG MZ42PZ10 advertised at the same price as the one on their site,
    as for the stand, on sale at various outlets for about £150
    total spent so far then £3150
    as for the tuner, any vcr or sky digibox will act as a tuner,
    and quite frankly the money saved so far would buy a pretty good sound system, that would completly blow the on board sound into oblivion,
    later on I will try find the ad for Richer sounds to make sure it is the LG MZ42PZ10 that I saw.
  5. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Yes the tuner or sound isnt a problem as i have a sony sky box and i also have a sony DVP-ns700v DVD player and a Sony STRDB 1070 6.1 Amp ( Bit of a sony thing going on here i think ) But inst there problems with trying to connect to a plasma as they dont have a scart connection . I know if you get the tuner it has 2 x RGB scart conectors on the back
    :confused: :rolleyes:
  6. Guest
    these RGB to plasma seem to be the flavour of the monthfound here
    http://www.rgbtosvideo.com/
    and buy a quattro so you can plug all your RGB stuff into it, then hook it to your Plasma
  7. Guest
    update
    Just found the ad for the 42pz10 model its in the August edition of what video tv mag
    Richer sounds ad on page 70
  8. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    thanks i will have a look :p
