Question LG Magic Remote lagging and not responding
Discussion in 'LG TVs Forum' started by ataim, Oct 16, 2017.
  1. ataim
    ataim
    Oct 16, 2017
    2
    ohio
    This is for my brand new 65 LG Oled (B7). The remote lags horribly. Often times it works fine for just a few seconds and stops. At times does not respond for 10 seconds or more. I do not think this is normal.
    I suspected interference so moved my router and unplugged other radio sources nearby but it makes no difference.
    Resetting the remote does not help.
    Am i missing something, or am I simply unlucky and this remote must be replaced?
  2. GAmbrose
    GAmbrose
    Jul 5, 2003
    1,171
    83
    Essex
    +259
    It's not normal. The magic remote on my B6 is really responsive and doesn't lag at all or drop out.
  3. smurf_2010
    smurf_2010
    Oct 30, 2005
    464
    43
    +171
    Mine lags occasionally as well since firmware updates in particular in Netflix and Amazon apps. 55EG960V (2015 model).
  4. ataim
    ataim
    Oct 16, 2017
    2
    ohio
    Are these remotes IR and need direct LOS to operate properly? I was under impression they are either wifi or BT.
