LG M1710A-BZ 17" Monitor with built-in TV
Discussion in 'LCD & LED LCD TVs' started by kawan2, Sep 6, 2005.
  1. kawan2
    kawan2
    Hi!
    Hope this is the right forum to post this question. If I buy the "LG M1710A-BZ 17" Monitor with built-in TV" for my PC, does it mean that I can also use it as a TV without buying a separate TV card for the PC and any other TV software?
    Specification:
    Resolution: 1280 * 1024
    Response time: 8ms
    450:1 Contrast ratio
    Is the above specification ok for watching TV?
    Thanks.
  2. carrollp
    carrollp
    Sep 3, 2005
    12
    3
    Bangor, Co Down, NI
    Yes you are correct.
    You can just plug an aerial in as well as your VGA and switch between them with the input button on the remote.
    My Brother bought one of these at the weekend from PCWorld for £199 and after fiddling around with the settings I was quite impressed for the price.
    It also has SVHS in , Nicam sound and Teletext by the way.
    There is no scart input but it has an adapter in the box to connect to a scart output using the AV input.
    PC
  3. kawan2
    kawan2
    carrollp, thanks for the info. :thumbsup:
