LG LRH 790 fw update
GoofyNascar
I am in canada and have the LG LRH 790 and was wondering if I can use the 780 ntsc fw update. My drive stop seeing dvd's and I replaced it with a new one model # gh22lp20. Now I can play some older dvd but the new ones errors out. Plus I cannot burn any programs off the hhd to dvd. Should I update the fw for the loader to sl40. Any help would be appreciated. :thumbsup:
Here are some info I gathered
Mod. Name: RH1000
region code: 1 N.A.
loader = 1.01 HD Size = 250
Set Ver - 60417a.nt
ops codes are 90, 20, 00, 79, 0e, 9e,03, 01
Thank you
GoofyNascar
pmac
I have the LG and it will not see a disc when I put one in the drive. I think it needs a new dvd drive . I'm going to send mine in for repair. I will let you know how it goes. I have Star Choice and I found out they are going to start to use copy protection(cgms and hdcp) so hdd players will not be able to record any more. I already had a few shows on A&E that would not record yesterday.
fgallichand
Mod. Name: RH1000
region code: 1 N.A.
Set Ver - 60417a.nt
Thank you
GoofyNascar
Hello GoofyNascar,
I have the same recorder, and naturally the same problem. I was curious to know how it turned out. You said you replaced the drive with a gh22lp20; does it fit inside the lrh-790? Were you able to solved the problems, and if so, how?
Thanks for the help.
Fgallichand.
