LG LN57 Stuck at Eastern Europe
Discussion in 'LG TVs Forum' started by churukah, Aug 30, 2013.
  1. churukah
    churukah
    Aug 30, 2013
    2
    Hi Guys,
    I've accidentally set the area option/EU_Country value from western europe to eastern europe on the EZ ADJUST menu.
    The TV is full functional but the problem is; I can't now change the setting back to what it was previously.
    Here's the full details on each element on the area option menu
    Area Code : 642
    Nordic UI: 0 (grayed out)
    Use HW Option: 1
    Wi-Fi Frequency 0 (grayed out)
    MHP 0
    HBBTV 2
    Isolator 0
    EU_Country EAST-EU (grayed out :rolleyes:)
    Arabic 0
    AJ/JA 0
    TTX_LANG: W_EU (grayed out)
    Any help would be appreciated; do you think it might be related to other tool option menus?
    Best Regards,
    Churuk
  2. Samorlg
    Samorlg
    Apr 16, 2008
    2,485
    +116
    Is there a way of resetting the Tv's factory settings without going into the service menu, maybe a plug and play option as found in Samsung tvs?
  3. churukah
    churukah
    Aug 30, 2013
    2
    I'm afraid the only option to reset is just in the setting menu. I tried to search for hard reset etc... It doesn't exist.
  4. cloaked
    cloaked
    Aug 24, 2013
    5
    I have the ln575s version of the tv and my area settings are also grayed out
  5. Diferent
    Diferent
    Oct 1, 2013
    Hi Churuk, have you sorted out this problem yet as having exactly same issue with my 55la660v. After one of the updates it stuck in East eu mode and I'm unable to change it. If anyone else came across this please help.
