LG LHT6740 600 Watt home cinema system
Discussion in 'Home Cinema Speakers' started by nits2004, Sep 7, 2005.
  1. nits2004
    nits2004
    Sorry, not great with this stuff.......I plan to get a home cinema system, does anyone have one of the above systems? I live in a terraced house, so would a 600w system be too much???. Or would i need to go higher?
    http://www.didstore.com/store_cat.asp?catid=2
    Any info on this would be greatly appreciated.
  2. GW43
    GW43
    Feb 27, 2005
    1,627
    63
    Out of my mind on dope and speed
    +162
    It's important to get a power rating based on an accepted standard, before you can compare power outputs of any equipment.
    Check the RMS power output of the amplifier section by looking for a statement such as: "Continuous Power Output All Channels Driven into 8 Ohms, 20Hz-20KHz".
    You should also be looking for a THD (Distortion) figure quoted at a certain power level.
    It's not unknown for some manufacturers to beef up their "power" ratings to make the specs look good.
    For a small/medium room I would say 40 watts per channel RMS into 8 Ohms all channels driven 20Hz-20KHz at less than 0.01% distortion would be ok. The sub should be a bit more than that however.
    If the seller/manufacturer can't/won't supply this info, be prepared to walk away, unless you get a written agreement to get your money back in full when the thing sounds too weedy when you get it home!
