S
searsp
Would appreciate an opinion on above. I currently have the LG model, about a year old, it doesn't have an optical input so I can't connect my Sky HD box directly to it.
I'm therefore looking for an all in one solution which does have an optical input and have been offered the Panasonic SCHT900 by a friend (approx £75)
I gather this was a very good model from 2003/2004, my question is whether the fact it is a semi-old system is going to mean the overall performance is less than my LG?
As you can probably tell, I'm not an expert on Home Cinema so any suggestions appreciated, even a one word response in terms of what you'd go with would be great.
Pete
Pete
