Hi there,
I bought this TV last week and have also been scouring the web for some suggested picture settings, but no luck so far. It's almost as if no one else is buying it
So having tinkered with this set for a good five days I've settled on the following:
Sky/Freesat/SD:
Backlight 40, Contrast 90, Brightness 50, Sharpness 0, Colour 55, Tint R2, Colour Temp Medium, Noise Reduction Off, Eye Care On, Real Cinema Off, TruMotion Off.
FreesatHD (BBC HD):
BL 40, Con 88, Bri 52, Sharp 0, Col 40, Tint R3, Colour Temp Medium, NR Low, Eye Care On, Real Cinema On, TruMotion Off
PS3:
BL 40, Con 90, Bri 53, Sharp 5, Col 43, Tint R2, Col Temp Medium, NR Off, Black Level High, Eye Care Off, Real Cinema Off, TruMotion Off
I've run the THX Optimizer off an Aliens DVD and for movies it suggested:
BL 44, Con 100, Bri 45, Sharp 32, (no B/F glasses for colour!)
Naturally these might look a bit gash according to your environment but have a go and see what you think. Any suggestions for SD setup would be appreciated
Also I have become aware of back light bleed ONLY in Freesat mode - a two inch strip the entire length across the top of the TV. Have you or anyone noticed this or is my set going back to the shop?
